ST170 MANI IN 2.0 ESP. Sensor question
Old Jul 5, 2011 | 12:58 PM
tompstomps's Avatar
tompstomps
Default ST170 MANI IN 2.0 ESP. Sensor question
Hi
Ive got a 2.0 focus ESP
Its got a cat back system with no centre silencer and is very loud
It also has the standard manifold and cat, which annoys me.
Ive bought an ST170 manifold from the bay, and am aware that i also need to find an ST170 flexi hose, in order to mate the mani to the 'zorst.
My question is, what do i do about the green and blue lambda exhaust sensor plug things??
Do i somehow attach them into the mani? Or just leave then unplugged? Rip them out etc??...
I.e. Are they needed for the running of the car? And without them it wont run, sort of thing.
Also, finally, the car WILL be de-cat when the mani and flexi are in, because in the 2.0 the cat goes straight on the mani, whereas in the ST170 it goes midway in the exhaust system. So basically where do i stand with and what do i do about the sensors?
Old Jul 5, 2011 | 02:06 PM
oldford's Avatar
oldford
No reply.
Old Jul 5, 2011 | 02:12 PM
RichieST's Avatar
RichieST
It will fail the MOT emissions test without the cat fitted, so you will need to swap back come MOT time.
As for the sensors, you will probably need to use the ST170 ones as the positioning of them is different so the wires are a bit longer. Either that or you could extend the wiring on your original sensors, which are currently positioned either side of the cat in its current location.
some of the early cars don't have a post-cat sensor, if this is the case, then fit the sensor to plug the hole, and chop the wiring off / tie it securely out of the way.
Anutternutter
24
Aug 31, 2015 01:24 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
track.focus'd
Aug 12, 2015 05:53 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
