Identify the electrical sender
Old Jul 6, 2011 | 07:26 PM
mattbrock's Avatar
mattbrock
Default Identify the electrical sender
Hi all
Hope someone can help - recently purchased an ST170 (my first) and love the car already - had a quick look underneath yesterday and found the below hanging down (next to gearbox on passenger side) in the engine bay - its only supported by the loom and looks like it should be screwed into something (has a thread on bottom) - only question is - what is it and where should it be screwed into!
Thanks in advance
Matt.
Old Jul 6, 2011 | 07:30 PM
Rs(555)'s Avatar
Rs(555)
Looks like a water rad temp sensor ??
Old Jul 6, 2011 | 07:33 PM
mattbrock's Avatar
mattbrock
Hmmm thanks... the temperature dials definitely working on the dash... i wonder if they have more that one sensor though (one for instrument cluster and one for ecu?)
Old Jul 6, 2011 | 08:35 PM
AWOL's Avatar
AWOL
Engine Builder
that ones normally used to switch on the cooling fans on the rad when the water gets too hot when stationary
Old Jul 6, 2011 | 08:41 PM
dakunia's Avatar
dakunia
Looks like fan temp switch, located in rad. Nothing to do with temp gauge at cluster
Old Jul 6, 2011 | 08:43 PM
As said water temp sensor, the gauge one and ecu one are seperate, and afaik both in the stat housing, although it seems odd, my dads neighbour who has a T reg mk1 focus 2L ghia has exactly the same in the same place, but car works perfect.
Old Jul 6, 2011 | 09:08 PM
RichieST's Avatar
RichieST
For starters it only has one coolant temperature sensor, which gives its signal to the ecu, the ecu then gives an output to the gauge.
That sensor ou have pictured is the under bonnet air temperature sensor, as the focus bay is quite cramped if it starts getting toasty under the bonnet then the cooling fans will come on.
It should be cable tied (that is the way ford did it) to the side of the battery box.
Old Jul 7, 2011 | 08:17 AM
Quality install again from ford, not hard to see why people think fords are a piece of shit when they do things like this!!
Old Jul 7, 2011 | 09:13 AM
Stu @ M Developments's Avatar
PassionFords Creator
Correct.
Old Jul 7, 2011 | 10:30 AM
RichieST's Avatar
RichieST
I think it's the crappy build that gives old fords their charm! If there was never at least one thing to mend then it would be boring
Nov 1, 2015 06:53 PM
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
stevecfrst1
Sep 30, 2015 05:18 AM
IainRS1700T
Sep 25, 2015 06:44 AM
Kam B
Sep 24, 2015 10:40 AM
