2001 focus water pump change q,s
Old Jul 15, 2011 | 03:26 PM
liam-rst's Avatar
liam-rst
shit happens
Default 2001 focus water pump change q,s
hi does anyone know if its possible to change the water pump without removing the cam belt, i only ask as its on an auto an really dont fancy trying to remove the lower pulley, is a 1.6 zetec s engine
thanx in advance
liam
Old Jul 16, 2011 | 09:13 PM
liam-rst's Avatar
liam-rst
shit happens
anyone?
Old Jul 18, 2011 | 09:06 AM
JonathanJ's Avatar
JonathanJ
ERM .... as it should be an SE engine in that and as they are chain driven cams you will not have a problem , the water pump is driven of the serpentine belt so is VERY easy to do
Old Jul 18, 2011 | 09:38 AM
DS81's Avatar
DS81
Fresh onion..
Defo don't have to remove timing belt, easy enough job to do, move expansion bottle/pas reservoir, remove aux belt, top timing cover, water pump pulley and engine mount. water pump is held on with 8mm bolts.
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
cameron2
Aug 25, 2015 07:18 AM
MARKYMARKONE
Aug 20, 2015 12:55 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
druidgetafix
Aug 15, 2015 10:22 AM
