ecu help
Old Jun 20, 2011 | 08:08 AM
sidewaysdave's Avatar
sidewaysdave
Default ecu help
hi there a freind of mine bought an escos form ebay a few weeks ago and the car has turned into a complete nightmere, it needed the head refitting but since this has been done it just wont run right. he has been told its got a 2wd ecu, and that is part of the problem, could this be the case?? it keeps changing the fueling and timing??. he bought the car with out looking at it and has learnt the hard way as its totally rotten as well. any help would be great
Old Jun 20, 2011 | 01:56 PM
Yes putting a 2wd ecu on a 4wd car will do this, the 2wd ecu can't run with a cat, as it has no control over it, it is also getting the wrong info from the throttle position sensor, the 4wd ones work the opposite way to 2wd, ie one goes from high to low and the other from low to high when opening the throttle.
It sounds a right bodge tbh.
Old Jun 20, 2011 | 03:01 PM
sidewaysdave
It is a bodge to be honest but it's his own fault he never looked at it before buying it theres so much wrong with it. Thanks for the help
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
griffo69
Oct 4, 2015 11:58 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
DixieTheKid
Sep 14, 2015 09:04 PM
Tank Mike
Sep 14, 2015 03:56 PM
