mk3 escort zetec conversion ,rev counter??
Old Jun 19, 2011 | 04:19 PM
smithy rs2k's Avatar
smithy rs2k
Default mk3 escort zetec conversion ,rev counter??
hi i did a 2.0 silvertop zetec conversion in my mk3 escort couple of years back but never got the rev counter working and its bugging me now ,any ideas how to do it thanks
Old Jun 19, 2011 | 07:04 PM
Could you graft a zetec cars tacho into your clock housing ?
Old Jun 20, 2011 | 04:19 PM
smithy rs2k
i have thought about a rev counter off ebay and trying to graft it in but i just wanted to keep it as original as possible
Old Jun 20, 2011 | 04:41 PM
Try tapping just one side of the coilpack negative pulse from the ecu, to see if you get it reading first, then you could try adjusting the multiplier on the actual tacho itself, but chances are you will need to send to speedy cables for modification, around Ł55.
Old Jun 23, 2011 | 07:19 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
as above, take one of the outer wires from the coil pack feed and feed this to the rev counter feed wire.
then take cluster out and adjust the pot under rev counter till it reads right, glue pot back in place and job done.
FlashRS
Sep 14, 2015 12:36 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
ekjim
Aug 17, 2015 08:57 PM
cozzy jeff
Aug 14, 2015 05:46 PM
stevierob
Aug 11, 2015 09:08 PM
