WAter pump on mk1 orion
Old Jul 20, 2011 | 07:22 PM
deano15's Avatar
deano15
Unhappy WAter pump on mk1 orion
Hi, logged back in and ready to finish my project. My mk1 Orion has been stood a while (9 months). I fired her up today and all looking good, however, heard a grinding/rubber screeching noise from near timing pulley. I knew it's not from top end as I rebuilt this last year and was running perfect. I looked further and noticed water pump pulley seems loose, as in I can move it around about 5mm. Could this be the root of grinding noises? Much appreciate any help as I spent a fortune re building head and carb last year and don't want to ruin these. Cheers
Old Jul 20, 2011 | 08:08 PM
studabear's Avatar
studabear
Seized up alternartor bearing? remove the alternator belt and start it up again, see if the noise is still there
Old Jul 20, 2011 | 08:20 PM
deano15's Avatar
deano15
I'll give it a go, just concerned about movement in water pump pulley. Cheers
Old Jul 21, 2011 | 03:51 PM
The water pump should have zero movement, it will be a rumbling sound when the pump goes, the hot water washes out the grease in the bearings eventually just going bang in a big way, so from your description I would say it's the pump, you'll soon tell by taking belt off and spinning, the noise from alternators tends to change with load so putting everything on will alter the noise if a bearing in the alt it will start singing, sound squite good actually!!
Old Jul 21, 2011 | 04:54 PM
deano15's Avatar
deano15
Tabetha
Thanks for the info, have tried alternator on full load and no change to the sound. Def water pump. Many thanks, keep an eye out fir me, will be in this alot over next few weeks
Old Jul 21, 2011 | 09:27 PM
At least it's a nice easy one to do, and cheap too.
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
155lee
Oct 27, 2015 04:55 AM
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
coscor86
Sep 20, 2015 01:21 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
