throttle postion sensor problem
Old Jul 18, 2011 | 08:41 PM
crystalbluecossiestu's Avatar
Default throttle postion sensor problem
i have a mk5 escort cab which is running a fiesta rs turbo engine, the wiring loom went up in smoke this has now been repaired by an auto electrician but the car now will not start with the throttle postion sensor (which has been changed) plugged in. If you unlpug it the car will start but won't rev up if i then plug the sensor back in it will rev up but only if you feather the throttle also the car wil stall this is annoying as it looks like the summer has already gone and my missis is dying to drive the car again as its been off the road for about 6 months
Old Jul 19, 2011 | 06:30 AM
Sensor wired around backwards, ie so it is reading full throttle at idle and idle when fully open ?
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
Dr. Ickxs
Sep 15, 2015 10:15 PM
mike elsome
Sep 14, 2015 04:08 PM
Marino
Sep 12, 2015 11:10 AM
mike elsome
Ford Range
Sep 9, 2015 05:05 PM
