no drive on st200....
Old Jul 17, 2011 | 11:14 AM
neil andeRSon's Avatar
neil andeRSon
Default no drive on st200....
As above. I went to shift my st200 that has been parked up for a while the brakes were tight but weren't seized. I got so far with It in reverse an I presume they stuck on. The back end of the car rose up. There's no feel with the hand brake. Now it feel's like there is no drive with the car. I presume the clutch has gone. How hard are they to replace?
Old Jul 17, 2011 | 03:41 PM
Clutch is a pig to do, mainly due to access, it sounds like the handbrake has jammed on with the car rising up, try and knock the lever arm off with a hammer, the usual place they stick is the pivot shaft, don't go mad with the hammer.
Old Jul 18, 2011 | 08:16 PM
neil andeRSon
Cheer's tab.. had a look tonight. The hand brake cable has snapped so hadn't even pulled on at the calliper. Clutch has deffo gone. The car can be started in gear an I can change gearwhen the car is running. I can get the car on a lift for doin the clutch. How hard are they to change?
Old Jul 19, 2011 | 06:32 AM
It's not so much hard, just so much crap to come out the way, buy a haynes manual I say, or see about cost of clutch fitment from garages etc.
Brickhouse
14
Oct 3, 2015 07:28 PM
stevecfrst1
Sep 30, 2015 05:18 AM
20/20 vision
Sep 29, 2015 11:27 AM
SMILER258
Sep 28, 2015 09:04 AM
