Rst efi tapping
Old Jul 6, 2011 | 02:00 PM
rsbolts's Avatar
rsbolts
Default Rst efi tapping
Hi tapping from top end put new lifters in but still same taps more when driving than ticking over oil light cums on Naw and again on tick over but goes out when reved up.could it be oil pump or warn cam it's a fiesta Rst engine
Old Jul 6, 2011 | 02:18 PM
martysmartie's Avatar
martysmartie
Assuming the light is accurate then your problem is down to low oil pressure, VERY low at that as the light only activates at low pressure. Either a pump issue or more likely engine wear, whats the millage etc?
Martin
Old Jul 6, 2011 | 02:32 PM
rsbolts's Avatar
rsbolts
Hi mileage unnow bought engine couple of weeks ago oil light was not when fitted but add the taping engine been in about 4 weeks
Old Jul 6, 2011 | 02:34 PM
chaffe's Avatar
chaffe
Turbocharging Technician
typical cvh, engine is fucked mate. Time for a zvh
Old Jul 7, 2011 | 06:22 AM
mattxr3i's Avatar
mattxr3i
oil pickup block easily on CVHs, could be this. Drop the sump and give it a clean
Old Jul 7, 2011 | 12:15 PM
martysmartie
One things for sure, don't carry on using the car until it's sorted as your going to do some damage!
Martin
Old Jul 7, 2011 | 02:47 PM
S1-Tiz's Avatar
S1-Tiz
sounds like bottom ends gone to me as thats what creates the oil pressure. Does it rattle loudest at around 3-3.5k?
Old Jul 7, 2011 | 04:20 PM
martysmartie
Silly question but you do have the correct amount of oil?
Martin
A.t.p
Oct 23, 2015 07:54 PM
A.t.p
Sep 29, 2015 05:04 PM
Billy_RS
Sep 13, 2015 04:17 PM
dms04
Sep 11, 2015 01:57 PM
