converting servo to abs
Old Jul 23, 2011 | 09:24 PM
snoopaloopa's Avatar
snoopaloopa
Default converting servo to abs
I can't see why but hope you guys can confirm/deny
Is there any reason that i can't do away with the crappy servo and replace it with an abs pump/accumulator setup?
I dont want full abs just the assistance and as i'm going to be fitting larger calipers over the winter I though this route might be beneficial?
As far as i can see the pump/accumulator is self contained when it comes to the pressure side of things and i am aware that i will,need an abs master cylinder as well.
Cheers.
Old Jul 24, 2011 | 07:50 AM
It's a long winded way around the crappy servo problem, but yes you could do what you plan, but why not just replace the servo ?
tankybaby66
Feb 6, 2016 02:24 PM
muzzman1
Sep 30, 2015 08:59 PM
