- MK3 Mondeo diesel engine swap
- Ford focus ABS & Traction Lights staying lit
- hissing from metering unit
- zetec conversion problem....
- ofac and ofab??
- Cossie misfire when warm
- question regarding long studing
- cossie loom identification
- turkish 200 block question?
- rs series 1 engine problem
- Mk1 Cortina 2 Door
- eagle rods and c20let pistons zetec silver???
- Focus Indicator Stalk
- What is this on a EFI setup ?
- Cosssy Indicators......
- bit of a strange question
- Speedo And Rev Counter Not Working
- ERST Temp gauge Question
- LED Bayonet bulbs in map readers
- Fiesta turbo help please
- swapping over a dipstick tube...
- Escort Cosworth MAP Sensor
- running problems please help
- overheating
- Mystery Misfire
- loud powersteering noise
- front bumpers s2
- s1 and s2 shafts same ?
- Fitting Air con to a sapphire, Help needed.
- mk6 escort cab dials
- Help with fuel leaks
- sierra abs problem
- Cossie 4x4 Tuning
- Thread speedo cable BC gearbox
- cant get 5th s1
- electric windows in a standed mk4 escort
- battery wires
- Fiesta rs turbo track car
- Car juddering
- sapphire cosworth 4x4 how to fit chip?
- 2.1zvh rattle
- oil my goodness - fiesta mk3.5
- fiesta cosworth
- What determines required compression ratio for turbo applications?
- my escort rs turbo s2 wont rev
- s2 rev limiter
- Front propshaft UJ grease nipple
- Running in?
- efi escort inlet on zetec engine????
- s1/s2 brake servo
- s1 4th jurking?
- new escos tappets, need running in???
- t3 turbo
- Help please!
- mk 4 3i efi running weak,help !!!!!
- descpro
- escort zetec engine - spark plugs oil
- will a mk 4 fiesta front take mk5 stuff
- 1993 escos power issue.
- 2wd cossie pin out?
- 3inch exhaust on a xr2 zetec
- 1600 x flow
- Piston marks
- SAPPHIRE COSWORTH 4x4 RADIO "ISO" CONNECTOR?
- bucket seats question
- Silver Top or Black Top?
- Info on how 4x4 systems work with transfer boxes
- 2.0 mondeo engine in fiesta si
- MAF Sensor Issues
- can i ditch dump valve
- help please stage 2 t3
- mot fail (rear bushes)
- Rs Turbo Rear Seats
- Rubber in propshaft knuckle
- gearbox ...spot the diffrence
- Plumming up S.P.A gauges
- Cosworth electrical gremlins!....
- Breather Pipe To Sump
- Poorly running RST...
- Mk2 rs Turbo Prolem
- Erst Metering Unit
- 2.0l zetec turbo in Mk4 fiesta courrier van
- 3i to Turbo
- Removing Inner Quads
- gear box help
- s2 box in s1 rs turbo
- quality cheap turbo
- TRACK CAR
- how to keep the oil dip stick tube in block
- New member - first car.
- Rounded Head Bolts
- engine management reset?
- Escort Mk4 Electrics
- What turbo damper on a tt38?
- how do i set my new tps sensor
- XR2 K&N and webber carb fitting problem!!!!!!!!!!!!!!!!!
- tt38 fitting probs
- cosworth bearings
- dipstick!
- L8 vs P8 ECU
- engine and gearbox oil (1.6 cvh)
- Piper bd 14 cam
- HCS Oil Seal being a b*tch.
- Ford Mondeo Stalls. Pls help
- capri wireing help
- Morette headlights not working
- cosworth pressurising
- megasquirt/ecufor numptys
- turbo diesel intercooler's?
- Diff cooler
- xr3i efi not starting
- RS1800 Diagnostics Help?
- co2 pot question
- help please !!!!!!!!!!!!!!!
- 4x4 Cosworth TCA Rubber boots
- Engine cutting out
- ford lsd gearbox
- nedd help lowering escort cosworth rears
- what spec pistons are these
- Fuel lines
- ecu
- parts from xr4x4 for cosworth
- s2 rs running problems
- Cosworth Rear Brake Hose Thread Size
- rs500 boost guage
- Escort rst brakes on a ka?
- Lean Engine
- central locking upgrade...
- S2 EFI Conversion problems!!
- Fuel-carbs? Stuck
- lamba sensor conversion
- What disc and pads for a rs turbo
- Bike Carbs - on a 1300?
- temp needle in red
- Zetec speed and temp sensors
- Ford Racing Gauges.....
- cossie pressurising
- Sierra Sapphire Cosworth Idle
- fiesta knocking sound problem
- please help... cossie oil leak problem???
- zetec 1.6
- Pectel P8 ECU Software
- Escort rs turbo sunroofs
- cosworth turbo water feed
- t34 or gt30
- Rs Turbo Running Problem
- Long stud torque settings
- cossie map sensor problem, car switching off HELP!
- Front Diff Help
- Bad handling...
- plenum spacer!!! plz help!!!
- Clifford Arrow 3
- Cosworth ABS
- mk6 escort 1.4 efi tuning
- mk4 escort lowering
- saph 4x4 head gasket
- Turbo and throttle bodies ???
- Escort Cosworth Throttle Position Sensor
- cosworth fuel regulator
- escort diesel estate
- Boost Guage Help Please
- series 1 efi wiring ofab conversion help in doncaster
- rs2k idle fault
- Ford V6 Distributor Help
- Oil Light on and noisy engine
- Where to get caliper piston
- Zetec Heads
- Fault with Racing Puma
- 1.8 zvh conversion help!!!!!
- Series 1 will not start!!!
- Sierra Cosworth brakes
- Interesting oil fact #3
- gti idle problems
- crank differences
- ZVH EFI Crank Position Sensor
- rs2000 4x4 loom
- zetec turbo help
- fuel cut off switch location fiesta rs turbo ??
- Need Help decoding casting number CVH Head
- electrical mishap
- fiesta rs turbo, no power to fuel pump ???
- 2.3 galaxy engine on cvh box???
- bit of pug help needed
- Using megajolt for 1.6 cvh
- Help needed!
- Boiling over
- Which Clutch 2.1 ZVH
- geraboxs please help
- GTI running fault????
- smoking cossie
- Escort RS Metering unit Problems (maybe)
- Escort Rs Turbo Proplem...
- zetec blacktop valve timing
- focus rooflining/grab handles
- Convert Escort from bolt to studs
- 24v cosworth v6(BOA) running probs
- caliper question
- Escort van steering problem
- oil breater seperator ????
- 2004 astra diesel fuel filter change prob-wont start
- 3dr Abs Loom Help
- efi head on an mfi block
- Fuel Pressure
- brake caliper\ brake caliper pin escort 1997 si
- saph heated windscreen
- 200 205 ? whats the difference
- cossi wont start
- gearbox probs! !
- Fan Relays
- Oil pump failing
- hi doers anyone know if i can still buy a ford cam for my s2
- efi turbo problem
- mfi to efi fuel pump
- Fuel crawl
- Tech heads needed. Whats this....pics!
- aprox flow/bhp cvh head
- Fiesta Rs1800 Zetec Trouble... Smoking?
- focus rs head gasket
- Steering Troubles.
- Cosworth Front Brakes On An RS Turbo
- can ya fit coz 4x4 discs and callipers on xr4x4 hubs
- HELP needed
- Dull battery light on dash.....
- power steering in a erst
- stage 3 chip?
- Change clutch help
- Recharging Air Conditioning In Ford Mondeo Lx Tdci Oct 2004 Model
- General Advice when buying a turbo
- frs brembos to fit my st170 hubs
- escort rs turbo 2.0 16v zetec
- exhaust knocking
- A dull topic but....Fiesta blower not working on position 1, 2, 3..
- Question: 2wd Sierra Cossie diff ratio...
- What Causes Boost Spike
- Compatible gearboxes for a mark 6 escort van
- Focus "Trip Computer"
- yb inlet plenum spacer
- Speedo cable help
- thread size
- Help needed for putting Zetec in fiesta mk2
- Escos Clutch problems
- cossie steering wheel
- Electrics
- Finis Codes for an Escort Cosworth
- Standard Focus RS Limiter
- clutch bolts come out! ! !
- Help Please
- no oil pressure, now not starting 1.8 ZT
- Cossie cold start?
