can i ditch dump valve
Old Jun 23, 2008 | 06:17 PM
carls9941's Avatar
carls9941
Question can i ditch dump valve
just brought a 93 4x4 saph cossie its only running 251 bhp but hope to up it to the high 300s problem is im ordering some new samco hoses but dont want a dump valve take off does not having a dump valve damage it in any way as i have heard so many stories any help would be great
Old Jun 23, 2008 | 06:40 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
You don't need it..
Old Jun 23, 2008 | 06:41 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
High 300s will mean a different turbo I should think, so make sure you order hoses to fit the new turbo you are fitting not the piddly little t3 if its still standard turbo at the moment.
Old Jun 23, 2008 | 06:42 PM
LHD220Turbo's Avatar
LHD220Turbo
dont need it with that spec; i run a 360bhp 2wd cossie without a dump valve; i just have a cone filter for the chatter (although i am getting a bit bord of the noise)
if your hoping for over 330bhp order the hoses to fit a t34, t3 wont make over 320-330bhp
Old Jun 24, 2008 | 07:33 PM
Phil2002's Avatar
Phil2002
i would personally run a dump valve if you don't want the noise then use a recirculating one.
Old Jun 25, 2008 | 09:16 PM
SS1's Avatar
SS1
some cars still chatter like fuck with a recirculating dump valve
mine does
i like to scare grannys at bus stops WTF WAS THAT
Ian1964
12
Jan 26, 2021 11:57 AM
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
RS-Rikki
Sep 21, 2015 07:27 AM
