Fault with Racing Puma
Old 11-06-2008, 10:40 PM
Doug
Doug's Avatar
Default Fault with Racing Puma
Friend of mine has just purchased a racing puma and it has recorded a fault code in the ecu
P0320 engine speed signal malfunction can anyone shed any light on this ?
He has already had crank and cam sensors fitted and as far as im aware ecu has been tested
engine has irratic idle and intermittently misses on idle if the idle is above 2000 rpm or under normal driving conditions above 2000rpm there are no noticeable running faults.
Any help would be appreciated.
Regards Doug.
Old 12-06-2008, 08:26 AM
Dal_
Dal_'s Avatar
Idle Control Valve? Sits on top of the inlet manifold top right on a Farpy. Maybe the MAF as well?
Old 12-06-2008, 02:08 PM
Doug
Doug's Avatar
No problem with the ISCV Nor Maf or Map sensors
Regards Doug .
Old 12-06-2008, 02:32 PM
Dal_
Dal_'s Avatar
CoilPack?
Old 31-07-2008, 09:41 AM
ali24v4x4cosworthvan
ali24v4x4cosworthvan's Avatar
hi there has he got it sorted yet?
try sitting it at idle with the clutch out and the clutch in, does it hunt when the clutch is in? and reving high when out?
mark94
Ford Mondeo Including ST
10-10-2023 06:52 PM
tankybaby66
06-02-2016 02:24 PM
The Youth.
30-09-2015 09:59 PM
youngben
27-09-2015 09:37 PM
Quick Reply: Fault with Racing Puma
