rs series 1 engine problem
Old Jun 30, 2008 | 11:22 AM
tony1's Avatar
tony1
Default rs series 1 engine problem
Hi my rs series 1 car broke down last week after only 500 miles after re build of 2.1 zvh engine. It would turn over and try to start but just cuts out. Took it into re performance in bury and he said that compression was down and one cylinder was as low as 30%. Whats likely to be the cause? any ideas. He took the head off and all looks fine and now he says he wants to take all the pistons out to check them. This car never smoked as it is all brand new inc pistons rings etc. Any ideas or help would be grateful or this could just go on and on .
Old Jun 30, 2008 | 11:26 AM
IANS2RST's Avatar
IANS2RST
has the head been machined at all? iirc you need to weld a bit of extra ally to one side of the head & then skim it so it will clamp down on the head gasket properly in that particular area
Old Jun 30, 2008 | 11:28 AM
mikedaf2's Avatar
mikedaf2
Could be a number of things but years ago i had the same problem and it turned out to be two pistons broke between the rings.
Old Jun 30, 2008 | 09:48 PM
Smartdj.'s Avatar
Smartdj.
either way not what u whant 2 happen
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Zoggon
Aug 10, 2015 10:39 AM
dlwarrior
Aug 5, 2015 10:19 AM
