Cosworth electrical gremlins!....
Old Jun 22, 2008 | 08:49 PM
kaboota's Avatar
kaboota
Default Cosworth electrical gremlins!....
Hi all
Wondering if anyone can help me resolve this.....
Cosworth 2WD F plate - electrical issue started with a bouncing rev counter needle but led to a now on/off working rev counter and temp gauge. Together with this, all linked i'm sure, the battery light comes on and sometimes the electric windows and indicators fail to work.....
The other day, the car completely shut down at 30mph, but I managed to bump start it back to life....Any possible cures would be greatly appreciated!
Regards
Kris
Old Jun 22, 2008 | 08:50 PM
rapidcossie's Avatar
rapidcossie
Sure the bouncing rev counter can be a faulty crank sensor?
Old Jun 23, 2008 | 05:20 AM
Rev counter will bounce when stalled anyway, but I would check the cps connector with the wiggle test.
Old Jun 23, 2008 | 07:58 AM
kaboota's Avatar
kaboota
The rev counter needle started off just bouncing when driving along, but this was a year or so ago but the problem has since got worse. The needle now seldom springs to life, or does not move at all and like I said the temperature gauge stops working at the same time.
Could this just be a loose earth? and if so where is it located?
Thanks
Old Jun 23, 2008 | 09:16 AM
Earth is brown in the multiplug, so maybe just try a seperate earth to see if it helps.
Old Jul 2, 2008 | 12:11 PM
kaboota's Avatar
kaboota
Fault seems to be rectified now.....was all linked to a loose multi plug behind the instruments.
Thanks for all your help
Old Jul 2, 2008 | 01:33 PM
cozmeister's Avatar
cozmeister
More boost Igor!
The one on the back of the instrument cluster?
Old Jul 2, 2008 | 01:47 PM
kaboota's Avatar
kaboota
Yep..not sure how many plugs behind there, but it was one of them that was loose. Jeff at GL Auto's in Iver, Bucks sorted the problem for me.
JK12
33
Apr 26, 2021 12:09 PM
Vacuman
16
Sep 3, 2015 06:26 AM
Aug 14, 2015 07:29 AM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
