Cossie cold start?
Old May 31, 2008 | 04:47 PM
moonstone_cossie's Avatar
moonstone_cossie
Default Cossie cold start?
before i rebuild the engine when i started her cold she high reved for a while and then calmed down to normal rev. but when i rebuilt the engine i replaced all sensors and when i start her now you have to keep your foot on the throttle so she dosnt die out. when she warms up she is fine tho! i tried changing the brown sensor the air/temp but i think its the water temp one any ideas?
thanks matty
Old May 31, 2008 | 05:07 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
sounds like your iscv isnt working....
Old May 31, 2008 | 05:14 PM
moonstone_cossie
my wat? lol
Old May 31, 2008 | 05:15 PM
JTECH James
Passion for Fords!
idle speed control valve.
grey unit on top of your throttle body.
it should raise the idle
Old May 31, 2008 | 05:22 PM
moonstone_cossie
ah right thanks
Old Jun 1, 2008 | 05:39 PM
A rebuilt engien is going to be tight, and the CO will have changed as a result of a new engine as well, so I would check this as it may be running lean a bit now.
carlo
24
Oct 5, 2015 08:20 PM
Adam-M
Aug 26, 2015 05:53 PM
The Enigma
13
Aug 20, 2015 09:38 PM
Archiejay
Aug 12, 2015 12:07 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
