S2 EFI Conversion problems!!
Old Jun 16, 2008 | 08:32 PM
Andy67_RST's Avatar
Andy67_RST
Default S2 EFI Conversion problems!!
Hi, i have fitted EFI to my S2 RST with cosworth management, but the car wouldn't start on a CVH firing order which is 1-3-4-2, so i changed the firing order to 1-2-4-3 which in the Haynes is an OHV order. it started on this firing order but ran really lumpy, miss fireing, and backfiring. Can anyone tell me what is the correct firing order for EFI and what sort of chip is needed to make it run correctly??
Any help very appreciated!!
Cheers!
Old Jun 17, 2008 | 01:07 PM
JesseT's Avatar
JesseT
Be warned, the haynes order is correct, but it starts on the wrong place for an CVH distributor in the Haynes picture. What distributor are you using or do you run a coil pack now?
Old Jun 18, 2008 | 02:16 PM
Andy67_RST's Avatar
Andy67_RST
I am using a cosworth coil pack, i have got it running in the correct firing order, but its running really lumpy and its idleing at 2000rpm, i cant seam to adjust it down, any ideas??
liamT74
Sep 23, 2015 10:24 PM
davidfordrs
Sep 21, 2015 04:23 AM
RSmark84
Sep 13, 2015 01:29 PM
dms04
Sep 11, 2015 01:57 PM
bigryrs
Sep 7, 2015 06:45 PM
