Rs Turbo Running Problem
Old Jun 14, 2008 | 05:40 PM
Donk1's Avatar
Donk1
Default Rs Turbo Running Problem
iv fitted an fiesta rs turbo engine with ofab managment in to my mk4 fiesta and got it started for the first time today but it is idling high and it cuts out after a little while and if you try and rev it it just cuts out can anyone help me please also the co2 pot is not fitted as i havent got one yet would this be the cause of my problem.
Old Jun 14, 2008 | 05:50 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Quite possibly. Running cars with sensors missing yields unexpected results.
Old Jun 14, 2008 | 06:26 PM
jammy86's Avatar
jammy86
I have this problem too at the moment. It'll run for a short while when turned on from cold but once it heats up a little and you press the throttle it dies. if you let go of the throttle as its dieing it'll idle again, but if you hold the throttle open it sounds like its ran out of fuel.
I'm not near the car at the moment so havent had a chance to play about with stuff but my suspicions are
TPS
CPS
Fuel pressure regulator
hth and to anyone else out there please help!!!!
JAmes.
big_Rad
Sep 15, 2017 09:36 AM
3i Jim
Nov 20, 2015 05:12 AM
Churtz
15
Aug 13, 2015 06:40 PM
Zoggon
Aug 10, 2015 10:39 AM
turbobill
Aug 9, 2015 05:21 PM
