stage 3 chip?
Old Jun 3, 2008 | 03:47 PM
RS SHAUN's Avatar
RS SHAUN
Default stage 3 chip?
ive been given a motorsports developments chip, to run greens, 3 bar map,and a T28
my spec is the same, but my turbo is a T3, will this chip be ok? its a L6 2wd saph!
the serial number on the chip is 3114
Old Jun 3, 2008 | 03:52 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
It probably wont be a million miles out, but you should go get it checked before ragging it - it'll most likely require some fine-tuning.
Old Jun 3, 2008 | 03:55 PM
KSA-Cossie's Avatar
KSA-Cossie
Pretty sure it won't do m8.
Old Jun 3, 2008 | 04:33 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
what cossie /ecu are u putting it in..????
Old Jun 3, 2008 | 04:37 PM
RS SHAUN's Avatar
RS SHAUN
2wd saph with L6 ecu mate
Old Jun 3, 2008 | 06:11 PM
Likely to get a small amount of surge as the ecu pegs the boost, due to higher than expected air flow from larger turbo, will only be slight or not at all, but get AFR check.
Old Jun 4, 2008 | 07:42 AM
Yura's Avatar
Yura
Yes, I think you need to check AFR at full boost and adjust boost for normal AFR
tankybaby66
Feb 6, 2016 02:24 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Mc5506
Oct 5, 2015 09:57 PM
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
