Cossie misfire when warm
Hi guys, as in title once the engine has warmed up and sat at idle for a little while it starts to splutter and cough and eventually it will cut out, it runs smooth under boost up to 28psi, I'm thinking coolant temp sensor but I thought I would ask you guys first. Cheers
Alex
Alex
hi mate have same prob with my s1, i belive mine is an electrical breakdown in the cable, i have changed all ignition side and still same
when cable gets hot it builds up resistence and broken or bad jointed cables can have a bad effect.
Russ Payne
Sep 25, 2015 08:29 PM
