aye folks,i am doing a stage 3 tune on my 3dr`s yb and am having trouble working out where the pipework runs to and from,i have a breather with 4 ports (2 low down on side 1 at the top on the side and one on the top) of the seperator,now i know one is from a hole in the cam cover,one goes to the catch tank,the only other pipe i see is from the "kidney box" between the block and plenumn,i was told i remove this and insert an adaptor,no problem.but this leaves a pipe that goes to the plenumn and one spare port to pipe up on the seperator,please can someone shed some light as its doing my tree in!!!
cheeRS daz
cheeRS,
so i leave the kidney box on then aah!!.the block adaptor i need i can get off ebay for around Ł9-Ł10,do need to take manifold off,which way up is your seperator as i have seen them with pipes from both top and bottom
mines different from yours!i have no catch tank mines just goes under the car to vent!mine has to pipes at the top and two at the bottom the top ones go to the cam cover and kidney box,the bottom ones go to atmosphere and the the block on exhaust side
this aint the best pic will take some later as i got to fit a coolant rad anyway see the bronze like connecter at the back of the block on the exhaust side?
yeh fella thats it!i will take better pics later!head gasket chap!but i went over the top and took the engine out and replaced every gasket all back together now and a empty wallet
i know how you feel i`m now saving up for forged internals after it was set up on rolling road,got the hunger for more power (best not tell `er-in-doors where all the money from the ebay sales is going!!! )
cheeRS daz
this might help if this is the set up your running
cheeRS bud spot on,am still unsure as to what to do with small bore pipe from plenumn as have been delving and removal of kidney box or flame trap is reccommended,watchathink?
hi,cheeRS for all the help chaps i have decided to sell my current oil breather set-up and buy the full monty spec-r group a jobbie
though am now looking at getting a closed loop lambda sensor set up so i can have it running better with more economy (cheeRS gordon brown for encouraging me to do so) does it ever end spending money on these bloody cossies there is always summat else to buy
