View Full Version : Ford Escort RS Turbo
- S2 interior into s1
- ive had enough
- cossie brakes on a s2
- Driveshafts-are XR's the same?
- Changing turbo
- anyone have 16" S1 alloys!!
- How often do you check your fuelling?
- Hydraulic Bonnet Lifters
- Spooky rear end
- fuel rail adapter...
- pulling to the left??
- co pot question
- escort turbo clutch trouble
- RS Turbo what head gasket to use?
- efi loom conversion
- little silly question about series 1 bonnets
- kent cams
- main shaft on gearbox
- Raised Bonnets and Washing (S2)
- 2.0 ZVH overheating.... Help needed!
- Management for carbs on zetec???
- Gearbox mounts
- new shoes on
- S2 ECU's
- koni sleeves...
- rear speakers?
- What can ERST give me?
- thinking of putting mud flaps on my s1
- wont idle, hot and smoking - head??? *help*
- help plz
- ICE
- s2 jacking covers finis codes
- s1 turbo bleeding brakes order reply needed asap!!!
- dodgy petrol reading
- cosworth brakes for s2
- clutch adjustment
- rs turbo s1 rear window caps
- worn piston rings
- 3 door steering wheel
- GRS INTERCOOLER RST S2
- fuel pump question
- takeing abs
- setting up the distributor
- High Rpm...
- cossie fule pumps and group a coils
- clutch
- focus brake set-up
- calibra pistons
- Crossover pipe
- AP 4 Paddle Clutch
- low compression pistons
- tinted rear lights
- Did magnex do a 3in bore
- White smoke
- Helpp!!!!
- anyone no this car
- paddle clutch plate ?
- mfi vs efi ?
- BG Automotive
- where's my badge go?
- rover inlet manifold
- strong s2 gearbox needed
- turbo bearings!
- black rst wheels
- show us your s2 rs turbo
- Coming back from a set up, dont sound good news.
- Engine tuning 150-160hp
- Escort RS Turbo Head Gasket
- NEWBIE TO THE TURBO HELP REQUIRED
- Would this Coil work..
- Bonnet raising blocks
- last escort rs turbo
- S1 Owners With....
- Radiator Leak
- s1 turbo what brake fluid is people using
- mmm.. mk4 escort with bm 320 engine in..
- Disc Conversion
- max power with std ecu's
- quick bit of help (pic)
- NGK plug gap
- This is funny!!
- Hairline cracks in Turbo housing?
- What kind modification driveshaft will need on the MTX75 box
- how much would u push a rebuild standard gearbox
- Brake Fault - Cutting Engine
- Big brake assembly problem
- help again
- Vernier Pulley
- big valves
- GT28
- anyone got a metering unit forsale in working order?
- vernier question
- Rod's and crank how much!!!!!!!!!!!!!!!!!!!!
- boost gauge
- Rs Van rear brake help?
- MTX75 VS CTS STAGE 2
- Anyone used a RS1600i solid lifter cam in a RST?
- s1- s2 fuel relay wiring
- newman cam help?
- EFI alternator bracket
- how to refurb a garret t3 turbo
- Achieving 250bhp!!
- injectors for EFI
- S1 central locking probs (something new eh!)
- ignition timing
- From MFI to EFI.
- Radiator Connections ?
- few piccies of my car
- CTS GEARBOXES
- where is the fuel relay??
- S2 starting when cold but not when hot.
- Swap for multispokes mint mondeo si alloys with tyres
- think ive gone gay.... or bufty lol
- Blue light bulbs
- Light Issues....
- is this turbo 2 big
- Whats this then
- ecu's?
- Show us your gauge holders
- Escort RS Turbo Header Tank Finis Number
- need some help urgent
- Turbo org, stg 1, stg 2, stg 3
- Mud Flaps
- MFI!!!!
- Standard actuator vs. -31
- Zetec Turbo Questions...
- smoking
- Lightweight 4 Pot front brakes for std wheels
- RS TURBO SPRING KITS WHICH ONE??
- is this place alright to you?
- best rs to sleeperise?
- thermostat water hose size
- Totally fucked off.
- -31 v -34
- abs system
- dodgy rev counter
- Grp A Coil - resistor
- brake help - re-plumb
- what power will it be?
- Steering bushes
- petrol gauge and temp gauge problem on efi erst
- edis wires and voltage,efi running problems
- Lowering
- inlet manifolds
- Bumper Inserts
- help!!!!!!!!!!!!!!1
- Series 1 Suspension "Setting up" HELP PLEASE!
- 12 second S1???
- DIY carbon fibre
- Rolling Roaded Today :-)
- engine choices for the RS, whats your opinons?
- fiesta steering wheel on escort...
- parts needed
- MFi beather system, how to vent to atmos.
- how do i fit a saab 9000 intercooler to my rs turbo ?
- Painting a dash board? (non chav)
- hose coming off crossover
- front suspensions
- how do i dial in a kent cvh35 cam??
- abs removal
- how far off tdc for a kent cvh 35 cam??
- zvh tensioner and cam belt... quicky
- another question, engine this time
- Buying an S2
- Decompression plates
- rs turbo lowering
- found my problem now fixin it!!!
- What power would be rqd for an escort rst to pull 170mph++++
- Ebay S1 arch JOKE
- Breather pipe??(with pics now)
- Think i've fucked it!!!!
- BCR 8ES plug Gaps
- cvh 35
- Escort MFI TPS
- would ther be much interest in my 90spec series 2 for parts?
- -34 Actuator
- kent 35 setings
- 2 modded S2's(can you work it out)
- BONNET PINS WHATS YOUR OPINION?
- fao safechav,post has been moved into here now
- Didnt Think There Go For This Much....
- One of the top RS's in the country
- TT 'v' SafeChav...
- Another Thread On S1 Decals.....
- Cleaning header tank
- what gearbox oil do you use?
- tca arms
- intercooler
- Breather systems???
- Safechav.....
- New S1 decals
- just a quick ?
- efi conversion question
- MY ENGINE SPEC HELP PLEASE?
- Stuck caliper??
- Bonnet problem!
- Best Oil
- Engine Bay Pic Database
- Radtec FMIC
- rolling road tuners kent???
- gearbox
- Idle
- Firing Order
- Help!! Anyone know what these callipers are?!
- paint??
- AGGHHHHHHHHH!! my cars gone bang!!!!
- Slight oil leak
- efi erst running problems,anybody help please
- MK3 original Ford rear Lights needed must be mint
- turbo choice
- Need one of these!!!!!!!!!!
- Who runs a newman's cam?
- Hot RST
- Another brake question
- s2 spining lots?usual?
- engine stand
- aquamist
- EFI Idle problem ( RS TURBO )
- Front Discs
- front oil seal
- Kent Camshaft CVH35
- Multi Plugs on Inlet Manifold
- Fitting a .48 exhaust housing to ERST T3
- RST Interior into Cabby???
- Roll cage.
- Sunday Driving
- Are these 4x4 cosworth calipers??
- black door panels,
- orion rs turbo exhaust?
- Helppp
- Sagging!!!!
- Problem with Timing
- anyone got a spare knock sesnor lying about
- Shes gone..........................
- anyone got a cambelt cover
- identifieng ofac map sensor
- s2 gearlinkage adjustment
- Fitting a T34
- oil pressure gauge fitting
- Help please
- Warm (oil cooler)
- saph cos leather into s2?
- GRS coolers
- Brake Bias valve question
- Efi conversion wiring. The 7 wires!
- series 1 rs turbo broke down already
- seat cardoba splitter
- wheel fitment
