S1 central locking probs (something new eh!)
Evening mk4 door lovers
Yesterday i spent a good few hours polishing my s1 after some minging brown shit stuck to the paint that looked like spots of rust had come through, so after 5 hours of this when i finished i went to lock the car and when i plipped the alarm the doors wouldnt lock, no noise from the mechanisms at all and every other aspect of the alarms locking proceedure is fine but it just wont lock and i can still pull my doors open from the outside which if you wanted to nick something you could just jump in.
has anyone had this before or any of you leccy guys have a usual suspects cause of faults?
im using concept 650i if that helps at all but any ideas i can play will help.
As always many thanks
Pete
Pete
It wont be the fuse if the central locking operates off the key.
THe alarm will probably have its own fuse tucked away somewhere really annoying to get to though.
Still on the drive, growing things from every available orifice. Ive not touched it
right just checked and no the central locking wont lock or unlock both doors off the key, i dont suppose there is somekind of over ride on the alarm i might have triggered that would stop it working the doors at all?
shut it you slag!
ive just checked the fuses and their all fine
i did push down the passanger side lock button when i was fannying about yesterday when it wasnt running and it worked before that
right, ive just swapped the 30 amp fuses from the locks and the windows over and no difference on the locks and the windows still worked and of course visually the fuses are fine, also i revved it to trip the anti hijack and it still locks the boot but not the doors, i think though that there is a slight noise coming from the doors when it should lock but its hard to tell.
any ideas mate?
any ideas mate?
Hmmmm, the way it works is theres a switch in the drivers door which triggers the central locking relay.
If it was the solendoid that was installed in the drivers door playing up, the boot wouldnt lock either. So the fact that its triggering must mean the switch in the door is being operated........but then the pin on the drivers door should go down.
fuck knows
![wtf.gif](https://passionford.com/forum/images/smilies/wtf.gif)
Its your own fault for being a wana be then
MK4 doors still allow you to have the pins, and it will be purely coincidence the passenger door only has a solenoid in it.
That said, just thought, has it still got mk3 central locking in it?
Aye im pretty sure it does chav, i actually got new pins from ford i just need to fit the drivers one.
something else to strip and play with next weekend then
I really cant get my head around this, might be something shit like a broken wire but it doesnt make sense.
It'd help if u whipped the door card off and had a peek to see what state the drivers door is like inside.
ive had that off before and its in decent nickbut im running out of light now so i cant go out and pull it apart, im gonna go and cover it back up now and ill see if its cured itslef just like it fooked itself.......
you never know
you never know
just been fannying about with it, theres still a clicking from the doors so somethings doing something
also there wa bits of movement on the passangers door pin so im just reading my haynes book just now
dunno, if its a solenoid stuck can i just wd40 it or something like that?
pc use now limited cos the mrs is on it so ill be back sooner or later
It Wasnt Me!
Ure missus got msn Pete?
Maybe the alarm solenoid has slipped off the pin that operates the lock on the drivers door? you know theyre usually screwed on so when the alarm solenoid operates to lock the doors it moves the door pin down locking it/triggering the relay to lock boot and pass door.....if that makes sense?
Fuckin wierd problem this one
The locks seem to be tempramental the now and the car is having track rod problems and my 5th injectors leaking
so no high boost for me for the time being lol
and
the disks are fooked
do any of you know if these will deffo fit my escort?
http://cgi.ebay.co.uk/FORD-CAPRI-ESC...QQcmdZViewItem
chav it is a clifford by the way and dave if it ever makes another west meet sam will prob be with me lol
the word sell seriously popped into my head today
and
The perils of buying a second hand 20 year old car i guess! All of the ones ive ever had have had loads of niggly things wrong with them but i take pride in putting them right and having faith in my own work
Discs you can't really grumble about - consumable item.
The alarm - what can i say its always the cars with cliffords that have issues
Can you not get track rod ends from your local motor factors, eBay isn't always the cheapest/easiest option.
![Rolling Eyes](https://passionford.com/forum/images/smilies/icon_rolleyes.gif)
aye track rods are quite common still so im on the hunt, im taking a break from it for a few days just now though then ill pile back into it.
ill love it again shortly lol
cliffords noramally use relays for controlling the door locking usually 2 one for locking and one for unlocking take a peep under the dash locate the unit and the relays which wil either next to the control box or taped up some were
change them just to be on the safe side probs faulty if they started working again its the same relay thats used for the horn the blue one under the dash
![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
07-10-2015 12:56 PM
rsguy
44
29-09-2015 03:29 PM
