Changing turbo
focus rs 1672
Originally Posted by Moose
that simple? a lad at work was sayin i had to remove the rad
cheers
cheers
i found it easier just removing the header tank and it slides out that side
you dont have to take the manifold off and you dont have to take the rad out. the only gasket's you will need is for the turbo oil return pipe!
if your handy with the spanners you can do it in 4 hour's, no problem
focus rs 1672
theres a bit in the front panel thats took out it to aid get the turbo and manifold out,but you really need muck about with angles not to chip front panel
undo manifold bolts
remove air filter box to gain access to lower hoses
remove all hoses and oil feed
remove header tank
get a piece of cardboard to put behind your rad so you dont damage it
undo exhaust down pipe bolts and your done
Originally Posted by SafeChav
Without a doubt, we ALL know the QUICKEST & EASIEST way is to get some other cunt to do it
its actually a delight to work on a cvh as everything is fairly easy to get to, except when youve spent £££'s and the cunt still aint right
Matt Baxter
16-09-2015 08:30 PM
siscossie
27-08-2015 09:27 PM
