what power will it be?
right have got a engine here with these mods
piper cam 285t2 kit
recond heads guids etc valves etc
rebore on .5 manhal pistons
crank regrind
stage 2 t3
31 acutator
exhaust system
air filter
new box and ap clutch
efi convertion ofac
195 chip
701 injectors
GRS front mount
just being built
what boost should i run
what will be safe to set this at
how long shall irun it in?
regards
piper cam 285t2 kit
crank regrind
stage 2 t3
31 acutator
exhaust system
air filter
efi convertion ofac
195 chip
701 injectors
GRS front mount
just being built
regards
i always used to run them very gentle for a few hundred miles then build the revs up progessivly until it reaches about 1k miles then get it set up by a pro.
run it on mineral oil for the running in period, i normally change at 100 miles, then again at 500, prob overkill but just what i do.
run a turbo pre filter while your running in, you can leave this on after but you dont have to i dont personally run one.
boost totally depends on what your fuellings like, somewhere between 16-22 psi more than likely, you will need to get this set up
deathrider666
28-09-2015 06:12 PM
