smoking
this is happenin to me, thing is i changed my stem seals and its still doin it
seams to not do it as much in the mornin if i take it for a long run,
i noticed there was oil in my crossover and other pipes does this sound
like the turbo is knackered?
rich
rich
Easy enough to change the stem seals. Just make sure the piston for the cylinder you are working on is at TDC incase the valve slips through the guide. Also be careful with the valve collets, a bit of grease on the valve stem will help hold them inplace.
Use the above stem seals and this tool....
![](http://im.edirectory.co.uk/products/1762/i/23310image.jpg)
rich
rich
i fitted that type of stem seal, i fort a small amount was normal, but i took the cross over pipe off and it had a bout 7/8mm thick line at the bottom and in the pipe where it connects and its coming out of my dump valve too onto the air box, soo i took the pipes off and washed them out, the week after i checked again and it was back to the same state
ps i only have a dump valve fitted cos i dont get chatter and sick of ppl thinkin its a replica
Worn stem seals will not cause oil in the intake system/boost pipes.
Are you still on a standard breather or aftermarket breather that is still connected to the metering unit (ie - not vented to a catch tank/atmosphere)?
i knew that they wouldn't cause oil in the intake but i dint know bout the oil in there till i changed the seals
, still on standard breather i fitted a new brether filter and i made bit less smokey so would a bailey breather maybe sort it? any ideas?
cheers rich
cheers rich
i had this problemw ith mine and later found out the turbo oil seals had gone.... might want to check for oil in the turbo entry pipe that goes from the bottom of the metering unit (air filter/fuel unit) to the main intake of the turbo. If that pipe has a recent trace of oil i would put my money on turbo seals. Oh and it doesnt have to be plooming out smoke for the seals to be gone. oh and thought i might add.... i changed my oil breathers too and still didnt sort it.
Steve Escos
01-10-2015 06:57 AM
