s2 gearlinkage adjustment
please could some one tell me the correct way to adjust my gearlinkage i have just fitted a clutch and i dont no the set up procedure,
thank you
thank you
i may be corected but thinking select reverse on gear box by pulling pin to neutral twisting all the way to drivers side then push it in towards gear box. then get a mate to hold gear nob in reverse location while you do up the clamp. let me know if that makes sense
