Grp A Coil - resistor
06-04-2007, 08:10 PM
Do you keep the ballast resistor wired in when you fit a grp a coil?
06-04-2007, 08:20 PM
06-04-2007, 08:22 PM
better go remove it
06-04-2007, 10:49 PM
it will work with one - but u will lose energy, bad move.
07-04-2007, 01:31 AM
Balls Deep!
BALLAST RESISTOR???
Just fitted group A coil what is this then??
07-04-2007, 01:57 PM
There isn't one as std on an RST - urs will be fine.
haz87
You don't mean the supressor for the rev counter near the coil do you?
07-04-2007, 05:28 PM
Its actually an Xr3i (mfi) that ive fitted the grp a coil to. So will this vary with needing the ballast or not
07-04-2007, 05:54 PM
07-04-2007, 05:56 PM
yer
07-04-2007, 05:58 PM
it maybe that the std coil is a 9v one, the resistor is then bypassed when cranking to allow a better spark. The grp A needs the full 12v, so u don't need the resistor.
07-04-2007, 06:02 PM
Superb! So the ballast is only there in ANY ignition setup to protect the coil yes?
07-04-2007, 06:18 PM
yes, and no... on points systems it was sometimes used to limt current through them to stop them burning out.
07-04-2007, 06:20 PM
Cheers for all the info rick, appreciated
07-04-2007, 06:22 PM
np
07-04-2007, 06:38 PM
Did an escort ever leave the factory with a ballast resistor
07-04-2007, 07:00 PM
Its a ford ballast resistor and everything,lol so i assume so
07-04-2007, 07:06 PM
that sounds like the rev counter supressor to me
07-04-2007, 07:08 PM
07-04-2007, 07:09 PM
Not a lot to be honest, the rev counter will work without it if you plug the loose ends together
07-04-2007, 07:11 PM
Its a little black box with two wires coming off of it. One red and one bright green. Sound like a supressor then?
07-04-2007, 07:13 PM
mark94
Ford Mondeo Including ST
10-10-2023 06:52 PM
01-11-2015 06:53 PM
A.t.p
23-10-2015 07:54 PM
07-10-2015 12:56 PM
beller
21-09-2015 04:13 AM
