Multi Plugs on Inlet Manifold
01-04-2007, 01:00 PM
can someone point out where the different coloured multi plugs fit on the inlet manifold just want to make sure ive fitted them correctly, theres a green,black,brown, cream,yellow and blue multi plug, some of the ports have colours on them so ive connected the designated plug to it but there r 3 which im not 100% sure about.
01-04-2007, 02:02 PM
From memory...
Green = Knock sensor
Black = Aux air/warm up valve
Brown = Thermo time switch
Cream = Not sure
Yellow = Temp sensor on bottom of inlet manifold
Blue = Cold start injector
Sure someone will be along to correct me
03-04-2007, 12:27 AM
Think you must of imagined the cream one
03-04-2007, 04:05 PM
Yeh got me confused aswell that one
03-04-2007, 04:57 PM
Isnt there a plug that goes on a sensor thats mounted under the Aux air valve ? Is this the elusive cream multiplug???
03-04-2007, 09:29 PM
Ive got a cream/white one left over after my re-shell.
Hangs around behind the inlet, i was told its a diagnostic port
04-04-2007, 04:59 PM
Get a picture up of it. Diagnostics on a RST, if only
04-04-2007, 06:30 PM
Yep, thats what i thought, i'll get a pic 2moz.
04-04-2007, 08:20 PM
05-04-2007, 09:11 AM
Heres my white plug....who knows what it is then? my car seems to run ok without it??
05-04-2007, 01:38 PM
Quote:
Secondary CTS for the ignition ECU, what year is your car and what code ECU do you have?
05-04-2007, 01:39 PM
And unless i am mistaken, that is in fact WHITE. and not CREAM
05-04-2007, 04:43 PM
I have no idea what year the engines from, its in a cabriolet.
i "think" its a 90spec one,how can i tell?
Ecu code? whats that? you mean the symbols on it?
05-04-2007, 04:46 PM
Yea, the coloured squares or if its 90 spec its hearts diamond hash
05-04-2007, 08:25 PM
Coloured squares, Blue Red and Black.
Whats that plug for then??
05-04-2007, 09:17 PM
Flywheel
sheps
Hi ya m8, can i have a look at the flywheel? bring it with you sunday iff poss, Cheers.
05-04-2007, 10:22 PM
Yes mate, if i have time to get it off, i'll bring it with me
06-04-2007, 04:05 PM
Quote:
06-04-2007, 06:27 PM
Whats CTS ?
06-04-2007, 08:45 PM
Coolant Temperature Sensor
07-04-2007, 12:15 PM
Quote:
Originally Posted by JimmyBoy
Whats CTS ?
My thoughts exactly!!
So where does it plug in??
07-04-2007, 05:29 PM
There should be a secondary CTS by the auxiliary air device, if you don't have one i have a spare i will sell because i never plan to run MFI ever again even if someone paid me to
11-04-2007, 07:29 PM
I have this one not connected as well, just remembered! lol, im not sure where the auxillary air device is to locate the CTS.
11-04-2007, 10:22 PM
Follow the hard plastic pipe connected to the throttle body and you will find it
tankybaby66
06-02-2016 02:24 PM
A.t.p
23-10-2015 07:54 PM
Fudgey
21
30-09-2015 06:19 PM
Johnny Knoxville
30-09-2015 07:21 AM
caprixpack
25-09-2015 07:53 PM
