EFI Idle problem ( RS TURBO )
ok here goes,, i have my escort rs turbo converted to ofab..
my problem is when i blip the throttle the Revs raises and holds for a few seconds before it idles down again..
i've changed the idle speed control valve. and it still does the same..
i took out the chip and it still does the same..
any1 any ideas?? regards dave
Is the normal idle speed ok ??, from what i remember when i had a fiesta turbo it would hold at 1000 for a few seconds before dropping to 850.
When my idle speed started to play up it was the TPS that needed replacing.
it doesnt seem to adjust when i screw it in or out.. but if i block the pipe that runs from the charge carrier to the iscv it idles fine..
is it, get the car to running temerature, unplug the ISCV,
then set the base idle? cos i tried this and it does fook all...
Matt Baxter
16-09-2015 08:30 PM
marky_g
15-08-2015 10:43 AM
Zoggon
10-08-2015 10:39 AM
