abs system
basically just remove all the belts and everything associated with the abs, i had to take the abs bulb out from behind the dash so there was no light on so it passed the mot, also u will need to block the 2 pipes that run to the abs system out the master cylinder, hope this pic helps.....
I've just taken mine off! It's alot easier with the head off or even still the engine out, but can be down with it in! Instead of blocking the 2 pipes just change the reservoir! alot easier!
