Radiator Connections ?
I'll cut to the chase - When you are looking down on the engine bay with the water bottle to the left, the radiator has 2 outlets, a big one (at the bottom) and a small one (halfway up rad), the big one goes to the expansion tank / block, where does the little outlet connect to ? (I need to go hunting in my shed for it, but not sure what sort of length it is)
Thanks.
Thanks.
That connection, the pipe should drop down, run parallel to the front cross member and then meet the front connection on the turbo which points downwards.
I have no pictures myself unfortunately
Mark RS
12-10-2015 06:01 AM
