ive had enough
Fife Radge
1 Post
ive had enough
of my s2 now the thing wont star and when its does it sounds liike a scooby so im not impressed. i need help to identify a problem im not getting any fuel out my metering head anyone know whats causing this ive got new injectors fule filter fuel comp and metering head to try out on thursday i think its the metering head personally anyone any ideas. when you take the oil cap off i can smell petrol its not strong though
Fife Radge
1 Post
whilst cranking, injectors cracked at metering head end, someone pressing down on the metering flap...does fuel come out then?
does the pump start? try to hum... standing still here...the word... "tvangstart" let the pump go all the time... still nothing?
and have u been changing the fuel lines from the tank? in that case, see if u did get the return on the return and not mixed them
when u let the pump go all the time(if u know how) u do it were the fuel relay is. then take of the fuel lines to the filter, and se if its any fuel there, then check if its on the other side of the fuel filter, if it is.. then check on the return.. if its any fuel there.. take it of by the fuel regulator
It Wasnt Me!
What Alex_86 is trying to say is, bridge the fuel pump relay by removing the relay and brigding the positive feed with a wire, turn ignition on, fuel pump will prime constantly and check for fuel before filter, after filter and so on.
Fife Radge
1 Post
Originally Posted by SaqsS2turbo
maybe because she ent fueling into all the chambers from the fuel not coming in problem thats why its sounding like a hot rod
NUTSRS i reset the timing to top dead centre i know ill have to move it back to 12 degress
prime the pump few times right and leave it for a bout 45 mins and push the metering unit flap down and check if u can see fuel piled up at the bottom of the meterin head
Fife Radge
1 Post
yh if u can see fuel flooded at the bottom of the metering head
i had this problem to u see so the float pin was leaking fuel badley and wudnt build preasure enuff for the injectors made it run lummpy etc
yup i done every stil carried on doing the same better to slap a new metering head on i found one for 30 quid the other night got it presto brilliant
well i jus changed my metering head back on my car and its workin now and we hav very simalar problems, does your car start for a very split second when left over night??
Fife Radge
1 Post
Originally Posted by jimmylaud
i can smell petrol from mine aswell but starts and runs fine apart from my other post what does that mean ?
that means you float pin is leaking after the car is turned off fuel is forceing its way out and floodeing into the inlet and wen u turn th ecar on it either runs lumpy or the fuel just gets traveled to the bottom of the intercooler into the other boost pipes
