Breather pipe??(with pics now)
Can some one who has a crank case breather system fitted post up some pics for me so i dont bolt mine in upside down and back to front.. plz
Or a detailed description..
I've fitted it . but i aint to sure about one of the outlets.. the 2 on the top of the tank go to either side of the rocker cover, and the big one off the bottom is the return back to the sump which is also fitted, But the smaller one on the bottom which is supposed to go to the metering unit is this one ok going to atmosphere as my metering unit is all plugged up???? and also what is the best way of blocking the small vacuum hose that used to be connected to the old breather system??
I've done this will it be ok??
![](https://i6.photobucket.com/albums/y215/hodgie_rs/DSC00018.jpg)
and fitted this .. dont fancy turning the key till someone says yeah it'll work . dont want the same shite to happen with the flooding again..
![](https://i6.photobucket.com/albums/y215/hodgie_rs/DSC00019.jpg)
still gotta block the vacuum hose aswell..
focus rs 1672
youve got 2 options mate,you can just block the left hand vacuum outlet or ust move your dump valve hose over to it and use the right hand for the ecu vac hose
also best runnin the breather to atmo,they never run right with the breather hooked upto the MH,mine felt jerky and idled pish with it connected,runs much better with it breathing to atmo now
155lee
06-09-2016 11:10 AM
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
chris m1
07-09-2015 08:02 PM
