- Waste gate
- sierra 1.8 cvh turbo engine???? can this be done?
- Help with 4x4 intercooler........
- MKIII XR2i CVH & MkII XR2 CVH Head/Engine Compatibilty??
- Engine Management light....
- help please suspension lowering
- bottom end bangin
- Amp / Sub Help
- Ignition timing for Antilag
- PLEASE HELP. COSSIE 2WD
- s2 wiring problem
- HELP PLEASE escort mk6
- 2wd saph earth points
- cosworth 2wd brakes
- s2 rst
- cossie 4x4 with the cuttin out fault update
- Fitting air/fuel gauge
- spark plugs melting...
- Blue & Brown plugs on ERST????
- filter size
- wiring
- 1AFA WIRING TO FIT OFAB
- hesitation??
- Problems fitting Greens to my Esc Cos
- braided hoses
- focus warning light
- DEISEL ENGINE PROBS
- Central locking on a 3dr
- 3 dr missing
- Oil Light On
- T5 that can handle 800lbs of torque?
- Ford Sierra Sapphire Cosworth 4x4 that keeps cutting out.
- Fitting Alarm In Mondeo Mk1 2.0 16v
- Torx Bolts
- 2.0 xr4i 0-60 times
- diy turbo rebuild
- Rough running RS...
- My engine got overheated, need some advice!
- what gearbox for a 4x4 cossie??
- No power under2000rpm after air filter change
- Is 15 psi between cylinders acceptable ?? on Compression tes
- rebuild advice
- got flow problems
- cossy holding back??????
- logistcal not technical help
- Best Oil for S2
- fiesta 1.25 zetec
- front brakes binding noise
- kidney box
- Part number for fuse box
- FITTING A BILLET FUELRAIL TO A ESCORT COSWORTH
- shutting down at 5000rpm
- Frst lump in EFi xr3i
- omex speed system
- 2ltr zetec bottom end help needed ugent!!!!!!!!!!!
- little ends
- wastegates
- Alloy size - advice needed
- Zetec Turbo Owners
- focus 1.6 zetec (2003) running on 3 cylinders
- Puma heater switch problem!!!
- DIY turbo repair
- are transit and sierra mt75 boxes the same?
- Escort 1.8 16v Belt help
- Focus not starting???
- escort gti bad running
- does anyone know the offset of the mondeo st200 wheels
- dismantling and building a t3 turbo????
- Strange Problem, please help
- 3dr cooling fan
- boost probs
- OFAC fault codes
- 24v tuning?
- focus rs calipers
- cars over fueling please help
- rs turbo running problem
- help rover transplant
- can i fit t3 compressor housing on my t35?
- TOCA RACE DRIVER 3 X BOX
- RS7 Spoke Wheels (STUDS AND BOLTS)
- manual boost controller advice.
- Who's running 0.48 exhaust housing on Escort RST
- would these tyres be ok
- T3/T4 turbo
- What CV grease to use?
- I see green spots... Paintwork Question
- v6 cosworth gearbox
- Aircon Issue
- Mysterious Cossie
- What could stop the injectors "Firing" ??
- are these calipers what i'm.....
- Clifford 600 Alarm
- new S2 metering head position?
- bailey turbo damper on 2wd cossie
- Diff and Driveshafts
- CVH head gasket
- sierra 4x4 gearbox question.
- numberplate stickers
- zetec blacktop pistons into silvertop
- CVH ROCKER COVER SWAP!?!?!?!?!?!
- FRST fuel pump relay?
- Smoke, But why??? *****SORTED*****
- Grey injectors and pintel caps??????????
- A few questions about 2.0 into fiesta!!!!!! ASAP
- Fiesta RS Turbo - No Spark and No Fuel.
- Zetec blacktop in a Mk6 Escort - possible?
- Tarmac Dampers
- rear ratios
- WB Lambda sensor placing
- rs turbo problems
- 2wd cossie box keeps locking in gear
- fitting rev counter clocks in 1.4 cvh efi
- esc cos ecu
- EFI Conversion and Sierra Pulley problem
- please,please help
- engine transplant
- Puma Help, anybody?
- VIBRATIONS
- How do i check a head for flatness?
- Mk5 XR3i Cabriolet Indicator stalk problem
- Can`t get in
- poor cossie starting (again)
- xr2i cylinder head
- mk3 fiesta engine transplant
- Whats the best way to split the exh housing from turbo
- cossie yb wont rev over 2500rpm
- Mk5b xr3i engine conversion
- Fuel tank breather
- Changing hydraulics
- power cutting out
- boost and gasket
- rst not starting
- wire probz
- refitting a cossie cylinder head
- BD 10 camshafts
- amal valve colours
- Smell of petrol inside the car...
- Oil in air box?
- how much can i skim off the head
- fuel pump
- Escort Cossie Multiplug Connectors
- carbon...
- problem with breather
- escort pulling back
- F.A.O FRST Owners Running ZETEC Turbo, Cooling advice needed
- transit connect speedo fuse???
- xr2i fuel pump relay location
- Engine Mounts
- help!! turbo not spinnin an d/v not dumpin anythin
- power steering loss ..
- new cossie problems!
- Cossie Starting Problem
- REMOVING THE FUEL PIPES RROM THE RAIL
- non starting focus
- fitting 1.8 zetec into my mark4 cab
- help please
- petrol in my diesel
- erst ecu chip identification
- relocating battery
- frst help please this is a weird one
- Clutch Cable 4x4 Saph
- rs turbo not starting
- cosworth mangement conversion parts list
- Horn on a GTi
- Cossie Chip
- Big Turbo Escort Cossie
- which ecu
- Fiesta RS/ ECU/SUPERCHIP problems
- Whining Quaife
- problems with ecu
- ahh handbreak gone
- Wishbones
- Any gearbox boffins out there?
- Zetec superchip Help
- need a 1.8 engine wire diagram
- cat on 1.8 zetec
- ENGINE PROBS help
- help needed with my saff cosworth.
- off set on wheels
- mk5 rs2000 engine torque settings????
- wheel clearance issues!!!
- ST24
- COSWORTH ESCORT CAMS
- Rattley Zetec 1.8
- Having starting issues with my Escort TD run around - UPDATE
- Scort hunting
- mfi/efi conversion
- new alarm help anyone?
- ap clutch
- Mondeo engine problems
- Zetec Crank Pulleys
- rst idle problem.
- hydrolic Lifters
- S1 intercooler
- best mods for 1.4 mk6 fiesta
- what offset
- zvh
- Turbo's, Superchargers and the dreaded dump valve
- hi hope you can help
- Puma Millenium leather recaros
- power steering
- where can i get an st 24/200 engine ?
- S2 ERST Oil Stem Seals??????
- bit of a problem!!
- Ford escort 1998 rear drums
- Sports Cat Noise
- WHAT LB SPRINGS DO I NEED??????????????
- FUEL PUMP QUESTION (RST AND COSSIE)
- changing shock absorber help please
- 2WD Cossie standard mains cap bolt torques.....in need of :)
- cosworth boost problem
- Help: Ford Fiesta Door Panels
- L6 ecu
- how to undo speedo cable from back of clocks!!
- escos head gasket
- focus starting problem
- Starting problem, possible starter?
- Phase sensor and crank sensor gaps...
- escort coss help
- Cut out :(
- crankshaft noise
- saff cos polly bushes
- Idle problems.
- Hydraulic Handbrake on 4wd and std brake system
- frst chip 165/195?
- 2.0 ecu probs
- suspension help
- ecu chip
- van wont rev over 3000 rpm??
- Banjo bolt for fuel filter - where to get a new one?
- Dump Valve Question
- vernier pully help.. how to
- Poorly fiesta.......
- Fuel pumps
- erst s2 help me keep her cool
- pinto and cosworth yb head
- Sapphire Cosworth Door Mouldings
- NO BRAKES
- Zetec help please
- tighting accelerator peddle???
- Fuel line Noise
- XR2i MAP Sensor???
- Brakes on S2 tubs
- ESCORT GTI
- Failed Emissions on CO level
- Tearing my hair out.....
- Head gasket gone!!!!! Best 1 t replace with????
- UPRATING/STRENGHTENING STRUT TOPS FOR COILOVERS?????
- Rs 1600i Twin anti-roll bars
