Is 15 psi between cylinders acceptable ?? on Compression tes
Old Jul 30, 2006 | 05:29 PM
nick series1's Avatar
nick series1
Default Is 15 psi between cylinders acceptable ?? on Compression tes
Just did a compressions test - 2wd cossie saph
got.
145 psi
140 psi
130 psi
140 psi
Have got a head gasket leak so it's possible that this could cause a variance !!
Is 15 psi an acceptable difference ???
Also is that compression ok ??? is it a sign of a warn engine ??
Any help would be greatly appreciated.
Old Aug 2, 2006 | 05:30 PM
Billabong's Avatar
Billabong
Some good info here: http://www.pumaracing.co.uk/comp.htm
Did you do a dry & wet test, and was the engine warm?
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
mondeomark
Sep 28, 2015 06:28 AM
