rst not starting
Old Jul 18, 2006 | 11:35 PM
rst230bhp's Avatar
rst230bhp
Default rst not starting
hello all
i have a problem with my s2 rst. i was driving it yesterday, car was ruuning ok
all of a sudden it started to back fire and the engine died, tried starting it again, it would turn over fine but just wouldnt start, left it for a while, it started fine, driving it again today, it started to jerk and the engine died again. it did start up again and know runs ok, i have been advised that it might be the fuel pump, i have checked the purple relay which seems to be ok. is there a way of testing the fuel pump. i know your supposed to hear it prime when you turn the ignition on, but ive never heard it before.
anything else i can check
pls help as getting quite pissed of with not being able to use it, especially when the weathers as nice as this
Old Jul 19, 2006 | 09:10 AM
SafeChav's Avatar
SafeChav
Right, what you need to do, is drive it again, until it cuts out then switch it off and leave it for more than 10 seconds, switch on, and listen for the pump priming.
The crank it over and listen for the pump running, i bet you find it will prime but wont pump when you crank
My guess is its the distributor sensor breaking down, if it does the fuel pump won't run, you could also whip off a plug lead and see if it sparks to earth....
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
JK12
33
Apr 26, 2021 12:09 PM
xrmalin
Sep 13, 2015 06:52 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
stevierob
Sep 7, 2015 07:09 PM
