power cutting out
Old Jul 19, 2006 | 12:52 PM
antcossie's Avatar
antcossie
Default power cutting out
hi there
i got a f reg escort and it works ok but latley its cuts out
its starts fine then i could be down the road and just dies on me then it wont start you have to leave it for ten mintues before trying again
it mainly happens when got full her up and cuts out dont matter if short of long trip
also if i start up on drive and leave it running does same thing only start doing this week
also something it gets so bad that wont start again and have to leave it over night and try again in morning
so people have said to me could be fuel pump or cap any ideas just dont want go buying stuff it dont need
cheers
Old Jul 21, 2006 | 04:01 PM
Well it is not the cap.
It sounds like something electrical, does the fuel pump run when you switch on(prime).
If it does not hot wire it and see if it then is ok, if it is then you are missing fuel pump feed.
If this is ok then you need to look for a spark, no spark could be the coil on the way out(gone).
You really need to ascertain if you are misssing SPARK or FUEL, then get back.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
Fudgey
21
Sep 30, 2015 06:19 PM
