Blue & Brown plugs on ERST????
Anyone remember where the Blue & 2 Brown plugs fit onto the engine at the back of the engine bay - directly behind the inlet manifold ???
Can't bloody remember ............
THE BLUE ONE AM SURE GOING TO CAOLD START VALVE UNDER INLET THE BROWN ONE ON TO BACK INLET BELOW THE COLD START AT BACK AND OTHER ONE GOING ON TO A WEE SOLENOID RIGHT DOWN BACK ATTACHED TO INLET AND HOSES CONNECTED CANT REMEMBER TECHNICAL TERM BUT THAT DEF THE THREE CHEERS HOPE YOU SORTED
almost fella
blue one going to the cold start valve
the brown one is the thermo time switch which is just under the blue plug as if it is pointing to the front of the engine
the yellow plug water temp senser going underneath the inlet pointing upwards hope these help
Mc5506
05-10-2015 09:57 PM
deathrider666
28-09-2015 06:12 PM
