wiring
Old Aug 1, 2006 | 08:49 PM
craig21t's Avatar
craig21t
Default wiring
hi i hope someone can help me, im fitting megasquirt to my car and im using the ford edis system, the crank sensor has 2 wires, both blue in colour, one with a yellow stripe on it the other with a green stripe. does anyone know which is the positive and which is the negative.
cheers, craig.
Old Aug 2, 2006 | 09:30 PM
JesseT's Avatar
JesseT
When the sensor is installed on the block, the upper pin is positive.
Old Aug 3, 2006 | 08:30 PM
craig21t's Avatar
craig21t
Default thanks...
thanks for the reply jesse but i dont know which way the sensor went originally, the sensor is being fitted to the front of my renault 21 turbo engine, as im running megasquirt. does anywayone have a picture of the crank sensor fitted so i can work it out please.
Old Aug 4, 2006 | 11:49 AM
Jay,'s Avatar
Jay,
Sponsor
bttt
Old Aug 4, 2006 | 09:24 PM
SafeChav's Avatar
SafeChav
Sorry to piss on your chips boys but how can inductive sensor that produces an AC signal have a positive and negative???
Old Aug 4, 2006 | 09:32 PM
Rick's Avatar
Rick
my thoughts too
Old Aug 4, 2006 | 10:02 PM
Jay,'s Avatar
Jay,
Sponsor
exactly but which is the input and output rick
Old Aug 5, 2006 | 08:24 AM
SafeChav's Avatar
SafeChav
There is no input/ouput?
Old Aug 5, 2006 | 08:34 AM
Jay,'s Avatar
Jay,
Sponsor
so its a continual circit then
Old Aug 5, 2006 | 08:42 AM
SafeChav's Avatar
SafeChav
The sensor doesn't have a power supply or anything like that if thats what you are thinking.
Its an inductive sensor, has 2 pins which across them produce an AC voltage, which varies dependent on speed.
Old Aug 5, 2006 | 09:04 AM
Jay,'s Avatar
Jay,
Sponsor
sorted lol
Old Aug 5, 2006 | 04:01 PM
craig21t's Avatar
craig21t
Default mmm
i understand what you are saying but this pic......
http://www.megamanual.com/ms2/edis4ew.gif
clearly shows it as a + and a -
???????[/img]
Old Aug 5, 2006 | 04:08 PM
Jay,'s Avatar
Jay,
Sponsor
just do as ur told and fuckin wire it up
Old Aug 5, 2006 | 05:42 PM
SafeChav's Avatar
SafeChav
That wiring diagram is bunk then!!
Do as Jaycos says
Old Aug 5, 2006 | 06:10 PM
craig21t's Avatar
craig21t
Default lmao
yes boss
Old Aug 6, 2006 | 10:00 PM
craig21t's Avatar
craig21t
Default ok....
ok you boffins were correct, didnt matter which way round they went. thanks for the help. she is running now
Old Aug 7, 2006 | 08:08 AM
SafeChav's Avatar
SafeChav
I'm not a boffin
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
cossie brad
Sep 29, 2015 02:38 PM
IainRS1700T
Sep 25, 2015 06:44 AM
