PLEASE HELP. COSSIE 2WD
Old Aug 3, 2006 | 02:38 PM
kyle5090's Avatar
kyle5090
Default PLEASE HELP. COSSIE 2WD
hi folks, my problem is my 2wd saph it drives ok most of the time then the odd its cuts out dead all of a sudden, then when i try to start it it just turns over. If i leave it for a minute or two then it will start as usual and drive the best until its next cutting out episode. It makes no difference whether the engine is warm or cold. I just dont know where to start, anyone ever come across this or have any ideas???
Old Aug 3, 2006 | 03:22 PM
Dave Henshall's Avatar
Dave Henshall
possibly fuel pump relay...?
Old Aug 3, 2006 | 08:01 PM
daz1968's Avatar
daz1968
I have the same problem on my 3 door, stopped twice this year, leave it about 10 minutes works fine, I have just started checking all sensor plugs and wiring but until it goes again have no way of finding it, I am carrying a few screwdrivers, multimeter and wiring diagram with me as I can only find it when its broke, but fuel relay or connections sounds feasible will attack that with the meter if it happens again. Unless there is any way to check it, I was also thinking of cleaning the terminals on the fuel pump just in case. So I am interested in any comments on this as unreliabilty is a pain.
Old Aug 3, 2006 | 10:56 PM
kyle5090's Avatar
kyle5090
its doing my head checked the relays out they seem ok, drove about tonihgt armed with a meter and a friend in to, and of course it drove fine!!!! will go out tomorrow to do something and i bet i get a mile and it will stop!!!!
Old Aug 4, 2006 | 12:07 AM
cossied's Avatar
cossied
Default cutting out
inspect the wiring from the crank sensor it has a tendancy to go brittle and the insulation breaks down. that is what happened to mine
Old Aug 4, 2006 | 08:22 AM
2001ode's Avatar
2001ode
Hi,
On next engine stop, look on your RPM counter, if needle fall down immediatly on 0, or if needle decrease with the speed.
If immediatly on 0, it is firing problem from ECU, if needle decrease, it is fuel problem.
Another test to do : autodiag.
Regards.
Claude
Old Aug 4, 2006 | 09:36 AM
lawnsy's Avatar
lawnsy
I had this prob and it turned out to be the FUEL FILTER ........
It would run for a bit then just cut out but would not start back up but if you left it 5 it would fire up no probs
Remember a lot of these have never been changed......and they are like 17year old now
mark r
Sep 29, 2015 07:27 PM
IainRS1700T
Sep 25, 2015 06:44 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
cossirob
Sep 3, 2015 09:17 PM
