fitting rev counter clocks in 1.4 cvh efi
hi guys, i've just put some rev counter clocks into my mk6 esc, but they don't work!, anyone know the pin outs and the best place to pick up the rev signal?
This is what you do when converting to efi on the RST.
You can run a wire from pin 11 on the E-DIS unit, to the back of your dash pod, to the tachometer input. This will give you a clean RPM signal.
Should be the same for yours but 100% sure.
dave
dave
JoeyBoyden
18-08-2015 05:56 PM
ekjim
17-08-2015 08:57 PM
cozzy jeff
14-08-2015 05:46 PM
