Mk5b xr3i engine conversion
Old Jul 19, 2006 | 08:58 PM
Bungle's Avatar
Bungle
Default Mk5b xr3i engine conversion
Hi peeps i have a mk5b xr3i 105 bhp and have also got a 130 engine, inlet, throttle body and ecu and was just wondering if everything will be a direct straight swap to convert mine to a 130 or is there anything else i need?
Thing is my mate says i need the engine loom aswell but as far as i'm aware the looms are the same between the 105 and 130 as the only difference in engines and ancillaries are cams, ecu, throttle body and the oil cooling jets in the block for the pistons,
If anyone else has any feedback or info that would be great so i can get on with the swap if i know i've got everything,
Any help anyone can give would be very much appreciated cheers, Grant
Old Jul 19, 2006 | 09:03 PM
sailorbob's Avatar
sailorbob
Default Re: Mk5b xr3i engine conversion
You'll also need the MAF sensor. Looms are the same.
Old Jul 19, 2006 | 09:06 PM
Bungle's Avatar
Bungle
Nice one mate you definately sure yeah??? Oh and i've already got the air flow sensor i just forgot to mention it cheers, Grant
Old Jul 21, 2006 | 12:32 AM
sailorbob's Avatar
sailorbob
What's the catch code of the two ecu's?
Dahl88
Aug 22, 2015 08:16 PM
marky_g
Aug 15, 2015 10:43 AM
stevierob
Aug 11, 2015 09:08 PM
Bloody-Fox
Aug 3, 2015 07:48 PM
bigup316
Aug 1, 2015 04:25 PM
