carbon...
Old Jul 17, 2006 | 10:46 PM
THE RADMAN's Avatar
THE RADMAN
Default carbon...
on the esc cossies how exactly does the carbon cannister work? i assume the fumes from the fuel tank are passed through this,neutralised then the solenoid opens and they are sucked back into the engine but what determines when the solenoid opens and for how long etc?also what is the valve that is connected up by the fuel filler pipe in the rear wheel arch for?always wondered and thought it was about time i found out,sure someone will know?
Old Jul 18, 2006 | 01:10 PM
sailorbob's Avatar
sailorbob
This is for the small turbo Escort Cosworth, I expect the large turbo is a little simpler.
The carbon canister acts a reservoir for the fuel vapours that are only allowed into the inlet manifold if certain conditions are met. The process for deciding purge solenoid dutycycle is;
The ECT has to be below 123.33 deg C.
Certain 'ECT at start' vs ECT and 'time since up to temp' vs 'time since start' criteria have to be met
Decide if purge at closed throttle is allowed (it is in the stock ecu)
The ecu has to be in closed loop operation (it can be calibrated to also do the purge in open loop)
Calculate purge solenoid dutycycle based upon airmass entering the engine (this varies from 4.69% at 384 kg/hr to 100% at 691 kg/hr)
Alter the purge dutycycle according to two purge timer values
Average the new dutycycle with the old dutycycle to prevent too large a change
Alter the purge dutycycle according to adaptive learning stored values.
As can be seen, quite a few decisions are made to calculate how much fuel vapour can be added without detrimental effect to the running of the engine.
Oh yeah, the valve near the filler is just a one way vent to allow air into the tank to compensate for the fuel used.
Old Jul 18, 2006 | 09:32 PM
THE RADMAN's Avatar
THE RADMAN
cheers for that its not simple then how do you know if its working then,what would happen if it packed up?
Old Jul 18, 2006 | 09:47 PM
sailorbob's Avatar
sailorbob
If the solenoid failed in the closed position then I don't imagine there will be any problem (I'm not sure if the injector pulsewidth is reduced to compensate for fuel vapour) until the canister cannot hold any more vapour. I guess once the canister is full then you'll get a smell of petrol from the tank or canister.
If the solenoid failed in the open position then the fuel vapour will constantly be venting into the inlet manifold and the short term fuel trims will recognise a rich condition and lean off the desired AF ratio to suit.
Old Jul 19, 2006 | 08:10 PM
ajjames's Avatar
ajjames
MY SMALL TURBO SMELLS OF FUEL OCCASIONALY ALTHOUGH IT DOESNT LEAK FUEL DO YOU NO WHERE THE CARBON CANISTER IS FITTED TO THE SMALL TURBO CARS
Old Jul 19, 2006 | 09:01 PM
sailorbob's Avatar
sailorbob
It's in the drivers wheel arch behind the plastic lining.
Old Jul 19, 2006 | 09:24 PM
THE RADMAN's Avatar
THE RADMAN
where does the ttank breathe from then?if theres a one way valve like u say to let air in,where does it let it out for expansion purposes?
Old Jul 20, 2006 | 06:30 PM
sailorbob's Avatar
sailorbob
Originally Posted by THE RADMAN
where does the tank breathe from
Into the carbon canister.
Old Jul 20, 2006 | 09:15 PM
THE RADMAN's Avatar
THE RADMAN
so if it wasnt working then the tank wouldnt be able to breathe?
Old Jul 21, 2006 | 12:27 AM
sailorbob's Avatar
sailorbob
I think there's no such such thing as the carbon canister 'not working', it's simply able to absorb the vapours or it's saturated and cannot absorb any more (someone shout out if I'm wrong). If the canister is saturated then I think this is when you'll be able to smell petrol fumes as the canister or tank will leak vapour.
