Rough running RS...
Old Jul 30, 2006 | 08:06 PM
RSOrion's Avatar
RSOrion
Default Rough running RS...
My car struggles to start, hav to hold full throttle, doesnt idle, runs rough, but also dump valve goes off wen just revving. Cheers.
Old Oct 8, 2006 | 05:46 AM
wildpikey's Avatar
wildpikey
hello mate usually the dump valve doesnt go off unless your revving the nuts off of it when its stationary if thats whats happening then thats nothing to worry about but on the samehand it could be your dump valve causing the problems,try taking it off and blocking the pipes connected to it and see if that makes a difference and if your dump valve is a diaphram type then they are no good for that car anyway you need a twin piston type. it sounds like you have a vacuum leak somewhere try checking all your pipes to your intake,intercooler,brake servo and all your breather pipes also check to make sure your dipstick is seated properly and your oil filler cap is sealed properly as all of these can cause the problems you are describing.
TPM961
Jan 15, 2018 10:50 AM
xrmalin
Sep 13, 2015 06:52 PM
BRAM
Sep 8, 2015 07:11 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
Rizlablue
Sep 6, 2015 09:58 AM
