View Full Version : General Car Related Discussion.
- Interference or non interference engine?
- Escort 55 1.8d Oil seals change ?
- Cosworth no spark problem??
- Can a Car Garage MOT The Vehicles It Is Selling
- Escort Van 1.8d Haynes Manual
- New Focus, no GPS signal ?
- Best car for around £1500?
- being Able to Track A Ford Focus and It's Registaration
- 1.3 xr2 ???
- Any Renault techs
- Escort Van Engine work in or out ?
- List of Quickest and fastest 4-cylinder 402 meter dragrace cars
- Help!! Mondeo gear select problem.
- test drove the new nissan qashqai today...
- Diesels, 4k to spend, show me what's hot.
- Just a thought..
- Standard puma manifold
- Classic ford
- best price for dent removal?
- gem module
- Anyone know about vw's
- Mk1 Capri 3000GT 'Barn Find'
- mk1 focus rs power limits.. ..
- Wilwood Calipers
- focus mk1 seat bolt 'T' bit size?
- Vauxhall techs. Corsa problem
- whats a really decent car cover for my fiesta rs turbo?
- Cossie front propshaft bolt thread??
- car accident today who's fault....?
- Ford parts depo help!!!!!!
- Hazard lights coming on on their own whilst driving
- Gearbox, diff & transfer box recommendations HERE >
- Car suggestions carnt make my mind up
- Touring Car Legends
- series one recaros how much????
- Low mileage..NOT!
- Piggybacking looms
- Ball joint splitter
- reliable 2wd big wing sump talk to me?
- Saw this on the mlr where cars go to die.
- golf vr6 only blowing slightly warm heater air!
- Stupid parts prices?
- rs1700t p13
- coil pack
- oil for the sierra
- Cleaned the inlet valves/ports on my audi fsi engine yesterday.
- Ford S-Max polyurethane bushes
- Ib5 gearbox ratios
- Parrot MKi9200
- mk3 xr3i on old style plates??
- Spit for Sapphire Cosworth
- Not what you see every day on PH!
- Skoda Octavia VRS talk to me.
- not firing at idle but firing once reving ? comp test now done
- Bonnet prop question?
- YB stat help
- Gibbon from Matlock?
- Bmw 330d e46 Talk to me
- escort mk4
- Strange question - what's the width of a saff lol
- Anyone use the car moisture absorbing bags?
- Cat D value
- Van broken into with no damage,how do they do it?
- Riffle Drilling
- mk4 Golf TDi tuning sites or PF help?
- Crossplane crank 'Big Bang' engined XR2 - anyone know much about this???
- Paul Walker
- shameless request for a capri
- Audi S4 (B6) v BMW M3 (E46)?
- Mot fail
- ford KA only blowing cold air!
- wasted spark
- Does this sound like a tensioner bearing?
- panel retrim in black mk4 escort
- Mk2 focus Rs calipers and discs on st?
- Ron Dennis & McLaren
- escort van conversion
- Hybrid Focus RS
- mk3 mondeo calipers on mk3 xr3i????
- 4x4 saph mongoose fitting issues :-(
- Ecu question
- sportka restoration
- Citroen C4 engine change, how hard??
- Any1 work at bmw? Could you check the history and spec of a car?
- Saph/3dr Rear strut brace, do they actually make a difference?
- Private Cars Cannot Be Sold With Road Tax From October 2014
- Private plate question
- group a?
- Fibreglassing Questions
- Sierra wraps
- Anyone retrimed an RS 3 spoke steering wheel in suede?
- f - super interface
- suprised how much ford KA's rot!!!
- car coons??
- Standard cosworth breather system?
- what engine is this
- New calipers, discs and pads = brakes binding?
- Petition to reintroduce classic car tax exemption
- fiesta rs turbo 1990
- Painting intercooler/radiator
- bosch 044 fuel pump
- 1996 LHD Escort Cosworth Lux at Auction....
- Ford transit broken into with no sign of entry
- Mopar Nationals Santa Pod
- Pro hoses
- What make and model was the last car which had the old Diesel Engine (in the UK)
- mk4 escort xr3i side trim
- Ball joint extensions
- LSD Rebuilds
- What car will go up in value the most in a few years?
- Honda civics new type R
- FAO People in the Bishops Stortford area...
- Gauges that light up green?
- Fiesta st seats in rst s2
- Smartbox/telematics removal
- Ford Aubergine
- How long would you say ??
- F800 YHB my car any know where it is now
- whos chip is this?
- This Years Car Plans
- Best wide band gauge/Lambda?
- What cams for t34.63 YB engine
- Fiesta Mk6 1.4 Duratec water leak
- Fiesta RS turbo boot release not working
- Are the escort orions rare now?
- Car Wise
- Fuel line reapair kits, Where from?
- Mk4 escort zetec conversion help
- Tight steering?
- Gt4 update
- Anyone know what this is off of?
- Mondeo diesel mk3
- Zetec Turbo Cam Timing.... A big secret?!!
- .48 to .63
- Best underseal to use
- Didn't know they made an Escort P100!
- Stiff engine mounts
- Fiesta/puma/focus rear axle spacers
- cheezy1 the robbing c**t!!!!
- Nice little beast
- Any brake experts? running out of ideas
- Recommended Diesel Remapping Specialist
- Who's used this plastidip stuff then?
- STOLEN MK2 FRS, white, hemel hempstead...
- Differences on ST170 Engine (Zetec Turbo)
- How abut this for a 'mean machine'
- turbo pre filters on oil feed???
- anyone know what these 2 sensors do?
- Fiesta Zetec s 2008
- ford focus 1.4cl year 2002
- Removing turbo on gt4
- Timing belts on Escort diesel van
- Twin fuel pump cradle..
- How low is your front splitter?
- Coffee powered P100
- trevor
- Focus rs mk1 group buy on 2 piece disc
- Bodmin area
- Enclosed car Transport
- MOT Testers - decelerometers / portable brake tester
- converting sierra to cosworth
- dry ice dent removal
- Pro Hoses
- sierra geabox tunnels all the same??????
- fezzer RS on the way
- Opie Oils January 2014 Competition
- turbo upgrade/suspension
- Paul-walker-santa-pod-tribute-day-tickets-x-4-sold-out-venue-
- Can you hire ford classic cars for weddings
- mk1 focus rs
- autosports show nec
- Any discount codes for autosport this year?
- fast ford?
- what the best way to paint my block
- porsches...and the cayman
- Aim Digi Dash Install Help needed..
- anyone had spraying / work on your RS by this guy in ashford, kent? (greame / graham)
- What micron element in EFG84 Cosworth fuel filter
- classic/capri
- turbo blankets
- MSD discount code
- Gearbox ratios
- G653 WPU escort Rs turbo. Where are you now?
- Budget buckets. ..
- Will focus mk2/3 Rs 20" alloys fit a mondeo st220?
- What splitters fit the st220?
- AN hoses and Fittings?
- zetec turbo blacktop spec?
- 20's Plenty and Speed Kills stickers
- Family car
- opinions please map and standard chip
- injector seals on a sunday in bradford ???
- Rallying
- Steering Wheel Re-trim (?)
- Anybody know my car?
- HOW MUCH?!?!?!?
- Handling or power??
- Sold Fiesta ST and now got an Audi A4 avant!!
- Anyone ever Microsquirted a cossy?
- Escort P100 pickup on EBay
- Escort mk6 van
- Bmw E93,anyone got one ? window mist
- Z20LET running like crap after a new cam belt fitted.
- 2006 focus 1.6 petrol
- Silvertop sump and rocker onto Blacktop?
- Opie Oils PS4 Competition Winner!!
- best car to buy for about £2000 ?
- Supercharger cooling
- Water Injection - Who Uses It?
- Want to buy a new car, do you buy on spec or mileage?
- 2014 to be another record year for classics
- Rs Turbo engine identification, HELP!
- L8 lamber ?
- Anyone know this EsCos in Carlisle?
- Thinking regarding dump valves..
- Alternative injector to Seimen 83 that I can use with L8?
- Ford focus estate rear lower control arms
- Lead-foot economy
- 4x4 propshaft
- megane 175 renaultsport
- Votex exhuasts
- Transit connect buying advice
- transit cuts out
- 100mm airtec or a 60mm pro alloy??
- Where can you get these joints from for multi link rear?
- Cheap Escos on Autotrader.
- Cant see him getting the asking price
- temperture gauge
- Cheapo 3dr cover
- Another what car thread
- cosworth or Evo?
- XR3i mk5
- Bleeding brakes 1 man method
- Bmw E46 330d
- Dpf and mot
- 1800 pinto
- Is anyone running AP brakes with 330mm discs under Judd/BBS LM/Lenso BSX wheels
- this months fast ford
- 106 gti hunting on hot idle.
- Service history
- has anyone ever refirbed shocks?
- Cossie chip with photos, who can tell me more about it?
- Not a Ford, but...
- Peugeot 106 rear wheel cylinder change
- Stolen!!!!
- Duratec Turbo Gearbox choice ?
- Number plate swap help with getting tax money back?
- Will this melt in the turbo?
- o2 sensor too close???
