Fibreglassing Questions
I'm needing some cheap cheerful parts made up for the Puma, 2 bonnets and some nice flat front door cards.
I got a bit of a bargain on a lot of some chopped strand fibreglass, the thickness I don't actually know yet, but I'm looking at the quantities of resin that will be required for it all.
I figure we're going to need about 9sq metres of glass for a single bonnet, 4sq metres for a webbing structure, and about 5sq metres for a single door card.
Now the door cards will be flocked so I don't care for the surface of it and the bonnets I am aiming to be wrapped with some funky colours so I'm not looking to paint any of the panels.
I've tried those online calculators but I'm really none the wiser.
Anyone able to shed some light on how much resin + catalyst I am looking to buy to achieve 2 bonnets, webbing and door cards, guestimating around 25-30sq metres of fibreglass.
Mac
Mac
Carbon Crazy
Its not as simple as that mac!
rule of thumb with chopped strand matt is you will use roughly 2.5 times the weight of resin as you will use weight of fabric. Youll want about 450 grammes per square meter of gel coat.
You need to measure those parts, work out surface area and number of layers of the CSM then you can calculate the resin usage.
