Bleeding brakes 1 man method
Yes get a 1 man bleed kit of ebay or halfords.about Ł20.You screw a cap on brake resovoir then connect pipe to spare tyre.The brake system is now pressurised,simply bleed through nipple as would do normally.
Does brakes and clutch,I swear by it.
Here's one on ebay.
160565784020
Here's one on ebay.
160565784020
Here's one on ebay.
160565784020
Here's one on ebay.
160565784020
Buy this one and you will never have a problem bleeding brakes on your own,eliminates pumping the brake peddle.Also comes with 3 different size caps so fits most brake reservoirs.
Here's one on ebay.
160565784020
Here's one on ebay.
160565784020
I wouldn't get one intime for Saturday lol not off ebay
as above halfords kit ,done an alfa 147 3 fkn days at it with 2 people b4 i found out the abs pump can only be bled under pressure will never do the old school way again.dont listen to the instructions i wouldnt go above 15psi on an old resevoir seen one explode on a nova at 25 psi
Screw a cap on the brake fluid reservoir, connect the other bit to a spare wheel, but as above, reduce pressure in the tyre first.
Once it's pressurised and not pissing out everywhere, go round bleeding your brakes, always furthest from m/c first, working back to the nearest. Making sure the fluid doesn't run out..
http://www.gunson.co.uk/item.aspx?code=G4062
Gunson Eezibleed - YouTube
Cheers mate.Ive never seen anything like that before lol.Think its a good investment.Im still gonna need my old easy bleed bottle and hose to catch the old fluid
I guess you dont have a small compressor?
One of the best tools i have bought is a vaccum bleeder that you use on a compressor.
Its amazingly easy to use, especially with 4-pots etc that have 2 bleed nipples per calliper.
I don't mate the only compressor I have is the mini tyre compressor to pump up the car tyres
Rubber hose to fit on the nipple.
End blocked off, I wind a bolt in it for a tight fit.
Slit cut into the side of the hose about half inch long.
End of hose in a bottle.
You can push fluid out but not suck air in, as the slit will open when you press the pedal and close as soon as the pressure drops.
No fancy tools or Halfords kits required.
Plenty of options
http://www.sealey.co.uk/PLPageBuilde...=16&fulltext=0
Pressure bleed kits are great, but so are vacuum kits too. No need for a compressor, vacuum is a simply hand pump job.
Even a big syringe and piece of hose will do if you had nothing else
