View Full Version : General Car Related Discussion.
- s40 ignition map
- BEWARE E-BAY seller RS Focus mk2 breaking !
- painting bare metal
- T34 on a BMW E30 2.5?
- some advice for buying a bmw
- Motorcraft parts
- Anyone work for Trackstar / Tracker?
- Guys from brigg lincs
- Subaru Experts
- Anyone know Mikey Buchan
- Inlet lengths
- Will a Mk1 RS200 fit on a Minno-Max?
- Zetec turbo advice
- turbo help......
- Max powa escort innit!!
- Any nissan techs on here?
- car sorn'd problem
- Focus RS Brembos quick question
- really?! RS2000 related
- 3 Door cosworth trim .
- fiesta / fusion 1.4 vs 1.6 tdci engines
- gripper quaife rwd diff
- t5 2wd gearbox tag ..................
- Power steering fluid
- Carburettors and Turbos
- Caliper carriers
- Best place for piston machining
- ford liverys/decals
- Moorfield Motor Services?
- Where can i get a Mk3 xr3 front bumper
- Dohc to pinto
- I think performance trim are back
- scan gague
- Fiesta 06 plate zetec
- mouses in my engine bay? how to remove?
- Cam cover
- pattern part cambelts , yay or nah ?
- Larger Calipers?
- air con retro fit?
- 200 block..
- good front wheel bearings for my golf mk3 vr6?
- injector flow checking .........
- Any car sprayers/painters on please? ** pics**
- 306 hdi problem, turbo, maf, etc
- Triumph TR7 - JPS edition?
- 07 Transit, piston 4 lost compression - how best to resolve?
- YB + Stack dash owners
- K + N Filter
- Compbrake TRE's - anyone use them?
- Engine timing
- anyone want to view a car for me ? rayleigh essex?
- Carbon fibre bumpers for Sapphire Cosworth
- The new fast ford, episode 328
- MK7 washer jets
- help need quick
- Anyone with a new ish glass guide car to do me a quick favour?
- vw bora tdi pd engine power loss problem
- Hydraulic clutch(Reyland)
- cosworth 200 block rebuild question....
- Braided brake hoses
- escort mk4 steering wheel
- 1.6 sigma with TI-VCT oil filter sandwich plate required for oil cooler.
- dose anyone know what wilwood calliper this is ?
- what sensors do i need for these gauges?
- Clutch bolts
- Fiesta 2006 1600 auto cold start cut out
- Paint work marks
- Zetec Turbo Cat Cams Valve springs
- respray on a p100 pick up?
- Manufacturing allignment jigs for cars. Anyone in the know?
- fuel cells/tanks, what you using?
- Help with my fusebox please
- big ass turbos !!!!!
- zetec turbo pistons help please!?
- Foucs wont start ...
- Sierra 24v strut brace
- its not a ford engine, but it might fit
- For the first time in 15 years Iam now......
- where can i find escort mk4 doorcards with speaker pods?
- How do car dealer warranties work?
- horseshoe switch around doorlock
- Turbo oil feed restrictor
- turbo oil feed pipe size help
- Rouse saff
- Is there a big difference between a bolt in cage and welded
- How to fit standard sierra front 4-pot brakes at rear?
- 909 numbers ford sierra rs Cosworth
- hpi check
- MOT question
- fiesta mk4 locking problem
- Can a MOD help me contact someone?
- Info on s1rst c333 gmb
- Best place for car mats?
- Mk3 Fiesta 5 Stud Front Hubs
- Twin plate clutch setup
- Diesel techs? PSA/Ford ?
- Where to get a lift pump?
- 1992 Escort cosworth central locking
- Worlds Fastest Production car
- Best place to get a GT30 Turbo rebuilt
- DVF 788T RS2000 help needed
- Recommend me a battery conditioner
- escort rs turbo
- Sierra Wing
- Opie oils
- waterless coolant
- Fiesta won't go into gear in the cold.
- UKs answer to the hummer
- Parts database
- Pumabuild
- Bbs fitment!
- Likey or no likey?
- what is the correct.......................
- Help With Identifying Escort Mk4 ??
- Focus rs engine in fez st
- Engine Paint Help?
- Auto Specialist Gear: What Say You??
- 3 door shells - seems legit...
- Can anyone help?
- citrine mk1 mondeo stranded in this bbc news artical!
- What was he thingking when he built this?!?!?!
- ZT Focus, Which ECU?
- Merc Vito Wing Mirror / Commercial Breakers in Herts?
- MOT testers? question for you.
- Carbon Escos, Did it get finished??
- HOW Lucky,,,
- 2015 Ford
- Value power??
- cosworth 24v help
- Please help
- MTX75 Clutch
- MONSTER World Rally Team: Re-launch
- Wheeler Dealer Mk1 Escort, What's it worth?
- State of our roads!
- black underseal to use that sets hard??
- Anyone own a seat Leon fr170 59ish reg
- Gt3071r turbo and
- Washing car
- Thruxton Driving Experience - Can anyone recommend one?
- Piper/Hales court case
- WTF is this for real
- RWD Duratec Conversion - Problems and Cost?
- Loctite flywheel bolts
- Price secondhand Parts sierra rs cosworth justified?
- Anyone just win a turbo cabbie on eBay?
- Anyone help me find a thread
- Focus geometry Qs
- Freezing central locking/doors
- new f1 turbo sound
- 2wd cosworth steering coupling??
- Will this work ok?
- fiesta turbo
- thread size ford racing gauge
- Cheap ST170 Problem
- AA recovery damage - MK1 Focus RS book price needed please
- Warning to all garage users during cold snap !!!!
- Escort mk4 efi fuel pump advice needed!
- Rs Turbo for sale
- 310mm wilwood brake kit questions
- brake disc paint...............
- Guesstimating car vinyl wrap material
- Do Cosworths Still Grab Attention? and Turn Heads?:)
- Which carbon fibre?
- Polycarb windows
- what else fits a type 9?
- ST170 or 2.0 Silvertop???
- where can i buy a roll of door membrane?
- Best budget brake pads
- bmw e39 m5 question
- Looks like he's at it again
- A big thanks to Boostmonkeys!
- yb crankshaft questions
- Can't believe what I've just seen
- MOT history check......
- Labour Rates - How do you price your work?
- Home made flamer kit help
- Who's is this black RST???
- rs2000 16v engine advice needed pls
- New Escort page on Facebook
- Water is a little deep ma lady
- 4-1 or 4-2-1?
- Are saph windscreen seals still available ?
- Replacing Ford Yellow Relays.
- nurburgring track repairs cost
- Its been a while...
- will a T34.55 do 400bhp.........
- Scam anyone? :-) looks dodgy to me!!
- rs turbo loom
- Removing Vinyl
- Bare essential guages for track use?
- BBC's 2013 F1 Coverage!!
- pars for a ten year old car obsolete already !!
- Cosworth prices..
- What Battery/Trickle Charger. Advice Please.
- S1 standard exhaust
- Rust Proofing
- Snow tyres on the van!!!
- HELP! I need a car transported from Southampton to Felixtowe
- Brand spanking new RS500 engine
- A favour following a death
- Potential HPI check issue
- Where can I get Number plates with the RS logo as the badge?
- mk1 escort with 120 miles from new!
- well lane turbo center? shut?
- Left handed right handed headlights what's the difference?????
- Passion BMW drifters, help re e36 328i
- xr3i efi
- Focus problem need advice pls!!
- fuel filters on citroen c4 hdi
- 4wd to 2wd conversion
- xr3i
- Disabling the ABS on a puma??
- injectors for 380bhp yb cosworth?
- xr3i efi
- Escort cosworth i seen today
- what car po;ish is silicon free? want to polish car in workshop
- The New Fiesta ST MY2013
- Best masking tape
- Omex single coil rev limiter/alternatives?
- saph shrunk door cards........prevention
- Converting my escort 1.3 hcs to 1.6 cvh
- still good people......
- ignition retarding
- Focus vs Mini
- dbt-e
- front brakes on the escort cosworth?
- Your views on this S1
- coolant problems
- 3 door Cosworth
- Another mondeo tdci thread
- Help with my Stack Dash (rainbird)
- People who know about Manifolds + De-cats
- ford freaks?
- A bit expensive
- Wiechers underbody guard?
- temperature problems
- Engine shops in central scotland?
- anyone identify these pistons
- puma 1.7 engine problem?
- 4.0 v6 will fit in sierra
- Focus c max quick question
- What year was ABS 1st used?
- Monte Carlo Day 1
- Thanks to Mark @MK Motorsport
- AEM EMS-4 in a Cosworth?
- Runners for recaros to fir mk1
- What daily car 4-7k budget
- Starter motor repair / overhaul
