View Full Version : General Car Related Discussion.
- best way to learn car wiring
- Ford Focus Boot Leak -06 PLATE MK2
- A good spraying gun to use? 2k paint etc......
- Who remembers this?
- .55 exhaust housing
- Uprated rear 4x4 diff advise
- How to find out which dealer car was brought from
- uneven brake pad wear.....?
- Fiat tipo 1.4 carb. model..
- Mk1 frs charge cooler issue
- Top feed intercoolers
- Water swill pots
- Massive front end banging noise
- Camshaft pitting question
- 2004 Focus - twitchy steering?
- Your top 3 US classic muscle cars ?
- SEAT anti-corrosion warranty question
- Does anyone have a 1.6 TDCi
- Rather large crank job I'm doing at work
- Ford fair track time.
- 3dr cosworth advertised..SCAM
- BC and IB5 oil grades ???
- Please help!!! Escort cosworth
- Airtec
- Intermittent misfire Mk6 Fiesta 1.4
- please check this ebay xr3i out WTF!!!!
- part number help
- Eventful drive to work.
- my e46 m3
- 14 plate Fiesta radio upgrade
- Geometry set up.
- 2wd vs 4wd?
- De-cat for petrol benefits?
- E99 knp. Rs turbo info wanted
- best wheels for a white Escort Rs Turbo
- XLD 1.6 alternator
- Breakdown cover???
- DIY Loom Repairs and Mods.
- Petrol octane additive
- RS 500 alternator adjustment bracket
- Cheap FRS mk3 anyone ?
- Any evo owners on here?
- Racing liveries
- Help Needed... 1.6 Zetec S
- Buying a car and legally driving it home?
- Advice on a newbie to RWD!
- MK1 Focus RS Boost solinoid location?
- Cosworth Plates
- Mondeo V6 tuning
- Dump valve
- Coolant sensor Ford XR3i
- Help needed on snapping alternator belt plz
- MK1 Focus RS Prices
- 8K to spend, What Car?
- Rear handbrake calipers
- Zetec turbo Pistons and rods?
- Evo Brembo's onto a 2wd Cosworth
- escort mk6 mondeo caliper upgrade
- Direct air feed to filter and rain help
- Seirra XR4i starter motor
- Inline turbo fliter
- Dump valve removal
- Mk1 FRS sparco seat alert
- Players Show - Goodwood
- Ken Block Transit anyone ?
- Dissabled cossy owner sos
- Ford Fair & Uxbridge show deadlines
- ST170 estate
- rouse 304 on ebay
- Main shaft bearing removal!!!!
- Mk1 sierra/3dr cosworth grill seal.
- Electric fan recomendations
- Tool advice
- temperature coolant sensor, where is it?
- Question for the CAD CAM people on here - MK - MT - people experienced in toolpaths
- Escort mk2 dash clock advise
- Claiming For A Tyre Under Warranty?
- Whats it woth post (sorry) s14 200sx
- Cosworth alternator heat shield
- Yb Timing marks help required
- Does anyone work for lex autolease?
- vehicle tax grouping question[trafic van]
- 1.9 tall block
- Run a Yb briefly with no coolant
- Mercedes main dealer faulty car
- So who's going classic ford??
- What size trailer
- My old car used in an ad.
- Larger front brakes for 2wd sapphire cossie
- Cosworth mechanic in munster area ireland
- Clutch for MTX75 - Zetec Turbo people
- paint polishing products to remove tiny scratches from wet and drying!
- Mondeo 2.2 into a connect?
- Any BMW experts?
- How do i tell if a light blue ford badge is real?
- Mondeo steering crunched to a halt? Zero steering
- Mk4 mondeo EGR Blanking
- escort estate window seals
- Evans waterless coolant....
- COLLINS -31 actuator for T4
- Can somone check this finis code please
- can you hire a focus rs for a day
- Sierra 1.8 LX 92 rear bumper?
- Indoor car cover for sapphire
- OFAM Expert needed.
- Advise on Sapphire front wings - screw or weld on
- 2.8 distributor in a 2.9 efi
- transit sportvan owners feedback please
- xr4i 58,000 miles value??
- Warranty or tough luck?
- 1.6 CVH cutting out/spluttering when hot?
- Motorsport Developments MSD
- 2wd or 4x4 sapph??
- Cosworth Crank Sensors ?
- e bay waste gate
- IB5 gearbox noise
- Sierra RS500 Lower Spoiler Fixing Brackets
- XR4i for sale (not by me).
- Ignition Management
- D599 XDO
- Dealer plates , where from ?
- Tube manifolds for 2.9 efi 12v
- E464 EFG engine rebuild and more power
- Stack ST 3312 boost gauge working in reverse?
- Cvh gearbox chatter
- Sierra xr4x4 2.9 replacement fuel lines
- Focus 1.6 TDCI 2007 won't start. Video added
- Bailey oil breather pipe sizes
- YB Exhaust info
- BOA Temperature sender thread size
- 1992 Ford P100 1.8TD engine converting to 2ltr pinto
- GT28rs
- When all other security devices fail.....
- Focus Window Switch
- BMW engine question.
- Electric tyre inflator recommendations
- Cosworth no start up (((
- Madness on wheels now on bbc4
- my £435 st tdci
- copper bake pipe kits....
- Best place for a Saph clutch cable?
- KA engine noise
- Xr4i tramlining
- Todays Spanish F1
- 4x4 fuel pressure regulators still available?
- mot test
- This poor 3dr cossie, anyones on here? :-(
- Mustang 717bhp
- Msd chip fitting
- Piper Release cams for the Ecoboost
- st170 shite
- Header Tank overflow
- Injector testing & cleaning
- T34 compressor map
- Escortrscosworth
- Sierra 3dr Permanent live?
- 700bhp
- Anyone know this 3dr
- mk motorsport adjustable beam.
- how hard is it to change rear wheel bearing on fwd mk6 transit
- Misses got me a new T shirt
- Help with petrol splashing out
- Hydraulic clutch conversion
- opie oils
- Martin Hadland Reyland Motorsport
- Battery draining after changing fuse box - driving me mad!
- Car finance, hiding a car!!
- battery light
- RS TURBO
- Central day was
- Tetrosyl Tetra Schutz
- Anybody got a standard cosworth 4x4 clutch release bearing to hand they could measure
- Mondeo 2012 1.6 Tdci Engine Malfunction
- Choosing your spec... YB
- fiesta mk3 steering wheel fit the mk3 escort??
- Thinking of buying a Volvo v50 any advice
- Dartford Crossing tolls and fines
- zetec copper clutch, advice needed.
- Water pump querie
- cosworth seats on ebay
- 3 door cossie fuel cap seal
- Alarm sensors
- Focus RS no 2733 VK53HXL any ex owners?
- DVLA surprise - tax
- Where sells sapphire lamp pods??
- ST-3 seats front and back in a mk6 escort?
- A government department gets something right!
- Pictures/Experiences with Dunnell Water Rail installed?
- Anybody looking for shared workshop space in West Berkshire?
- mo5 comps with evo brembos
- Got these gems out of the garage
- EBC Brake Shop.co.uk great service
- Photo Competition help please :)
- Courier for a Propshaft
- FRS to ST
- *** Sierra Cosworth Roof Lining Material ***
- Rear diff cover torque setting and sequence needed
- Any body shop recomendations in essex, to geta few little bits sorted?
- Golf GTI Clubsport S takes FWD 'ring record
- Fuel Resistant Sealant
- GT28RS
- Tuner in the east midlands.
- XR3i 1989 valuation
- Need a new RS logo reg plate - where from
- Reporting an illegal driver... Anyone done it?
- Help with a holset.
- T5 gesrbox nose cone
- Recaro retrim, Can anyone recommend anywhere?
- Hunter alignment - independent versus chain branches
- New Focus RS
- Mk4 Fiesta Puma Build.
- Looking for a 3Dr Cosworth soon.
- Escort mk4 vin number stamp help needed
- New User from USA with Volvo/Blacktop/questions.
- 2.9 efi 12v
- Cosworth 3dr misfire just before boost
- juddering from a new clutch
- pagid brake pads....,..
- Ball bearing turbo on cvh HELP!
- 4x4 Saph how to make them Handle???
- Group a headgaskets
- Morrisons bargain alert
- Radiator paint
- Dealer plate supplier?
- Fiesta ST dead.. What next??
- Ford Fiesta mk4 to Puma 1.7 engine swap
- FIESTA RS1800 Front and rear camber
- Flared arches for esc cos racecar
- Headlights
- Body shop advise wanted
- Anyone having trouble waiting on parts from Ford distribution center in Daventry?
- pinto/cosworth oil pump, where to buy from?
- Msd set up/ live map
- Carbon fibre
- 1st crash of a new frs ?
- Big thanks Cossynut2
- K-Sport Brakes....Any good?
- Mk1 FRS hydraulic clutch
- Cheapest and most reliable turbo engine for my rs turbo
- £1500 for a daily, what to buy?
- Ford sync issue?
- Ex Delecour Sierra Cosworth A7 FMC
- Supra/Weir diff oil
- May 8th decisions decisions????????
- Couple of nice cars up for auction at Manheim Plymouth next week !.....
- used 4x4 front brake prices
- Mk1 Focus Rs question.
- New car for commute..?
- Mk2 Focus RS help,
- MSD Launch control N/W
